SY-300 - Amp Perc Organ: 3 years in, the best organ I have
Started by Rhcole, February 11, 2018, 11:30:19 AM
Rhcole
I have made many organs for the SY-300. This is based on other patches I've posted, but it is stabilized and is the only one on my current patch set. It has a rock-solid organ sound with a 5th and octave for the percussive effect. Ctl 1 increases the volume of the organ, Exp varies the rotary speed.
If you don't have an Exp pedal, use Ctl 1 instead to vary rotary speed and set the organ at a volume you like.
The "Amp" designation simply shows that I use a guitar amp for the regular guitar instead of using additional FX on the organ sound.
ElliotG
Another very nice patch.
This example has CTL1 on, the guitar is still prominent in the mix.  Some very interesting choices in the patch.  The treble booster overdrive on the thru brings in the character of the guitar, and provides a nice contrast to the sin waves that create the organ sound with the pitch adjusted at -12 and +7.
In the example I used the expression pedal to slow down the rotary effect during the final sustain.
