Removing and inserting USB
Started by rocks_are_stupid, February 09, 2018, 04:10:07 AM
rocks_are_stupid
Noticed I've got into a habbit of turning my GP 10 off before removing or inserting the USB, started doing this because I was paranoid of corrupting my GP-10.
Is that a habbit I can put to rest?
Original Music/Videos using only the Vguitar
www.YouTube.com/YourNewEmpire
www.Instagram.com/Your_New_Empire
www.Facebook.com/YourNewEmpire
Redvers
I doubt devices are talking if you're not editing/saving but it's not a bad habit to have.
Usually a good habit to plug the USB before power on and after power off.
CodeSmart
Quote from: gumtown on February 09, 2018, 05:02:15 AM
During the development/production of the MIDX-20 I have hot-plugged USB's in and out of GP-10 about 800-2000 times, Katana about 500 times and GT-1/MS-3 maybe 250 times.
Not a single problem.
However the GR-55 I'm afraid of. I've had it corrupt once by sending shitty MIDI data into it.
Quote from: CodeSmart on February 09, 2018, 06:18:21 AM
I do NOT recommend insert / remove USB cable, Firewire cable, or Thunderbolt cable, or the GK 13 pin cable while gear is powered on
http://slideplayer.com/slide/4825825/
If gear is powered on, there is inrush current to the USB PHY ICs that occurs with each USB cable insertion, and this adds strain on components and leads to premature failure.
all computers built today have "smart" USB ports, and many computer USB ports will become auto- disabled if too much current is being consumed by the connected external  USB gear
With all my music gear I always make all cable connections and turn volume down before powering ON ,
and I always turn volume down , then Power down before disconnecting any cable , including USB.  - and my 20 year old gear still works
Essentially this same verbiage is included in the most Owners Manuals today.
CodeSmart
Agree. Not good for circuits, noted.
I was mostly referring to the question about the possibility of losing patch memory/settings if you (however not recommended) do hot plug/unplug 1000+ times, and no, I have not seen it happen with my abused and mistreated Boss GP-10 unit.
I'm a bad gear owner, too impatient. I'll probably end up in Silicon hell  :'(
rocks_are_stupid
#6
Quote from: Elantric on February 09, 2018, 06:30:51 AM
You Power down both your desktop AND your gear? or were you refering to just powering down your pedals?
Quote from: rocks_are_stupid on February 09, 2018, 09:02:20 AM
My gear is only powered on when im using it
I power everything off when im done.
I use a separate computer for internet
vtgearhead
<sigh...>  While developing the Fender Mustang bridge code, I had my Beaglebone computer shut down abruptly several times when hot-plugging a USB hub.  It handles it fine at steady state if it's there at initial power-on, but the hot-plug transient is the straw on the camel's back.
