Orange OMEC teleport Stomp USB Audio interface
Started by admin, April 26, 2018, 09:15:56 AM
https://orangeamps.com/omec-teleport/
MONO TO STEREO
Mono IN and Stereo OUT with a parallel buffer. There's no limit to what you do with your signal. Now you can experiment with stereo effects from a single channel input signal.
LIGHTWEIGHT
Built in a robust but lightweight pedal enclosure.
9V POWER
The OMEC Teleport uses the same 9V DC input as your other pedals.
INCLUDES AMPLITUBE CS
A complete, full-featured guitar/bass amp and effects rig for your iPhone, iPad and Android that includes a single track (expandable to 8 tracks) recorder for capturing your performances on the go. It features tools, tones and controls that will inspire you beyond your wildest expectations. For no cost, you will get the standard AmpliTube CS with the virtual OR120, Tiny Terror, Rockerverb 50, AD30 and matching Orange Cabs.
HIGH-END AD/DA CONVERTERS
We use high quality analogue to digital and digital to analogue converters to ensure perfect sound replication, allowing for an amazing signal to noise ratio. Even with high-gain signals, enjoy less fizz and more tone.
BUFFERED BYPASS
We use a buffered bypass to avoid the tonal effect of adding additional cable to your signal chain.
AUDIO   1-IN / 2-OUT AUDIO INTERFACE WITH 16-BIT DELTA-SIGMA DAC – ADC 44,1KHZ / 48KHZ SAMPLE RATE AUDIO QUALITY
HIGH SIGNAL – NOISE RELATION SNR = 96 DB
LOW HARMONIC DISTORTION THD+N = 0.01%
BUFFERED BYPASS
CONNECTORS   INPUT: 1/4" HIGH-QUALITY BUFFERED INPUT WITH 120DB OF DYNAMIC RANGE (MIC COMPATIBLE WITH A XLR-JACK ADAPTOR)
OUTPUT: 1/4" PRO-LEVEL STEREO OUTPUTS FOR CONNECTING TO STUDIO MONITORS, D.I.S, P.A. SYSTEM, PEDALS, AMPS, ETC
INTERFACE   USB 2.0 COMPATIBLE WITH IOS, ANDROID, MAC AND PC
MIDI   COMPATIBLE WITH JAM ORIGIN MIDI GUITAR
UNBOXED WEIGHT   0.149KG / 0.328LBS
UNBOXED DIMENSIONS   L – 9.2CM/3.62″ X W – 3.7CM/1.45″ X H – 4.8CM/1.88″ (INC. SWITCH)
POWER   POWERED BY 9V DC (NOT POWERED BY USB)
But only 16 bits = Alesis IDock / Behringer IS-202 level performance = lots of hiss and noise with IOS Guitar apps, makes this pretty useless for me for Guitar FX
