Boss Launches the GT 1000
Started by Mark Haydon, January 24, 2018, 12:09:33 AM
I believe this is the "Smartphone" version of Boss Tone Studio for GT-1000 ( iPad/Galaxie Tab S3
https://info.shimamura.co.jp/guitar/news/namm2018-boss-gt-1000/?ref=sinftn
https://translate.google.com/translate?sl=ja&tl=en&js=y&prev=_t&hl=en&ie=UTF-8&u=https%3A%2F%2Finfo.shimamura.co.jp%2Fguitar%2Fnews%2Fnamm2018-boss-gt-1000%2F%3Fref%3Dsinftn&edit-text=
BOSS- "GT-1000" Introduction of the 32bit / 96kHz correspondence model realizing the highest class sound quality
January 24, 2018  BOSS The NAMM Show 2018 Multi effector
When an article price or selling price is posted in an article, that price will be the one at the time of the article update.
When contents and prices differ at the time of browsing, products sale may be included. Please note.
- BOSS - "GT - 1000"
Open price ※ We will post as soon as the selling price is decided
JAN: 4957054512507
Release date: scheduled for April 2018
【New product announced NAMM 2018】 BOSS "GT - 1000" is a super - high - quality multi - effector of 32 bit / 96 kHz system which is adopted also for DD - 500 Delay etc. We are gathering state-of-the-art DSP technology and experiences of making BOSS's effect amplifier to a waste-less compact housing.
Equipped with state-of-the-art amp and processing technology "AIRD" (Augmented Impulse Response Dynamics). This allows you to faithfully reproduce the "interaction of the entire amplifier" and its "complicated operation" that were supposed to be impossible with the floor model.
In addition, it has many built-in effects designed based on the advanced algorithms adopted also for compact pedal X series MDP technology, multifunction model MD-500 Modulation, RV - 500 Reverb etc .
■ Reproducing the sound of tube amp at a high level State of the art "AIRD"
"AIRD" (Augmented Impulse Response Dynamics) succeeded in designing the amplifier at a high level which was considered impossible in the past. Blues Cube, KATANA and other designs based on the concept of "Tube Logic" is followed.
Ideal tube amp sounds preferred by players are created by mutual influence of amp parts and sections. This "AIRD" is a next-generation technology that reproduces the physical and electrical characteristics and behavior of the amplifier thoroughly.
■ The best class effects group
Many high quality effects are adopted which adopted algorithms inherited from DD - 500 Delay, MD - 500 Modulation, RV - 500 Reverb etc, including classic distortion and overdrive. In addition, a powerful DSP engine makes it possible to switch unprecedented high-speed patches. It helps seamless and stress free play.
■ Sound editor to provide stress-free sound making
BOSS Tone Studio
With the Bluetooth ® function, you can use "BOSS Tone Studio" (image for PC) sound editor · iOS / Android compatible application. You can manage sounds, editing, etc wirelessly on the smartphone screen.
If you use USB, you can also use sound editor for PC / Mac compatible PC. It makes it possible to create sound with higher visibility.
The LED of each foot switch can change the lighting color. By coloring the settings and each effect type, visibility of complicated presets is improved.
■ Features
Floor type guitar · amplifier / the highest peak model of the effect unit born with thorough pursuit of sound quality and expression power without compromise
It achieves industry's highest class ultra-high sound quality of sampling rate 96 kHz, AD / DA conversion 32 bits, internal operation 32 bit float (floating point) processing
Equipped with a newly designed BOSS custom DSP engine designed exclusively for musical instruments
The latest AIRD (Augmented Impulse Resonance Dynamics) technology embodies the Tube Logic concept as a floor type unit, allowing sound design as intended in any connected environment
Numerous expressive rich AIRD amplifiers with exquisite sound and response born by complex interactions of the entire amplifier
Many high-quality BOSS effects including advanced MDP effect, advanced algorithm transplanted from DD-500 Delay, MD-500 Modulation, RV-500 Reverb
Effect chain chain function that combines series / parallel connection of amplifier and effect with various routing
Equipped with ultra-high speed tone color switching and delay / reverb carryover function
The STOMPBOX function allows you to share settings with multiple patches, and you can change the setting as easily as when connecting a compact pedal
Equipped with 10 foot switches and expression pedals that can be assigned freely and the LED color can be changed freely
High precision tuner equipped with two display modes and compatible with both mono / polyphonic
Built-in Bluetooth ® function enables wireless patch editing / management from a dedicated editor compatible with iOS / Android
■ Spec
Sampling frequency: 96 kHz
AD conversion: 32 bits + AF method * AF method (Adaptive Focus method) is AD conversion
Roland / Boss proprietary method to dramatically improve SN ratio
DA conversion: 32 bits
Effect type: 116 types
Memory: 250 (user) + 250 (preset)
Phrase · Loop: 38 seconds (mono), 19 seconds (stereo)
Tuner internal detection accuracy: ± 0.1cent
Control: BANK ▼ switch, BANK ▲ switch, CTL 1 to 3 switch, 1 to 5 switch, POWER switch, EFFECT button, MENU button, EXIT button, WRITE button, PAGE button, 1 to 6 knobs, OUTPUT LEVEL knob, expression pedal
Display: Graphic LCD (512 × 160 dots, with backlight)
SUB OUTPUT (L, R) terminal: XLR type, PHONES terminal: Stereo standard type , CTL 4, 5 / EXP 2 terminal, CTL 6, 7 / EXP 3 terminal, AMP CTL 1, 2 terminals: TRS standard type, USB COMPUTER terminal: USB B type, DC IN terminal, MIDI (IN, OUT) terminal
Power supply: AC adapter
Consumption current: 1.2 A
External dimensions: 462 (width) x 248 (depth) x 70 (height) mm Pedal inclination Maximum time: 462 (width) x 248 (depth) x 95 (height) mm
Weight: 3.6 kg
Accessories: AC adapter, instruction manual, "Safety notice" leaflet, warranty card, Roland user registration card
Optional items: Foot switch: FS-5U, FS-5L, FS-6, FS-7
Expression pedal: EV - 30, FV - 500 L, FV - 500 H, Roland EV - 5
* 0 dBu = 0.775 Vrms
Smash
Am I seeing effectively 4 parallel chains there - serious horsepower under the bonnet! Looks like a Helix Fractal FX killer
Quote from: Dale007, post: 25693360, member: 190347There is support for custom IRs. Confirmed a few posts ago.
I'm from the "Show ME" state ;)
and to be precise - I'm talking about the ability for the GT-1000 owner to actually load THIRD PARTY CAB IR *.wav FILES (OwnHammer, Celestion,  - NOT just the Roland / Boss approved finite set of "AIRD" Cab Sim choices )
https://www.ownhammer.com/store/
https://www.celestionplus.com/
Speaker Cab IR Solutions
But in 2018 to not boldly state:
"Boss GT-1000 SUPPORTS LOADING Speaker Cab IR Infinite Response Files"
anywhere on any press release seems a serious omission )
Here is the official word
https://www.boss.info/us/products/gt-1000/
QuoteAIRD enables the GT-1000 to smoothly flow into any creative setup, allowing you to enjoy great tone and response with minimal adjustments. By choosing from a large selection of AIRD Output Select types, you can perfectly tailor the GT-1000 for any destination, whether it's a guitar amp input, an amp effects return, a power amp driving guitar speakers, a computer DAW, or a full-range monitoring system.
AIRD is fully integrated into the GT-1000's amplifiers at every level, so you'll always experience their authentic sound and interactive response no matter what you're connected to. And with the ability to apply different AIRD Output Select settings to the main and sub outputs, you can optimize the sound for two destinations at once, such as a guitar amp input and a direct feed to a house PA.
http://www.yomiuri.co.jp/adv/life/release/detail/00050640.html
https://translate.google.com/translate?sl=ja&tl=en&js=y&prev=_t&hl=en&ie=UTF-8&u=http://www.yomiuri.co.jp/adv/life/release/detail/00050640.html&edit-text=
Remember this is the same company who thinks all the Patches you will ever need will be at Boss Tone Central)
. . . Not
GR-55 Guitar Mode Patch Exchange
https://www.vguitarforums.com/smf/index.php?board=67.0
https://translate.google.com/translate?sl=ja&tl=en&js=y&prev=_t&hl=en&ie=UTF-8&u=http%3A%2F%2Fwww.yomiuri.co.jp%2Fadv%2Flife%2Frelease%2Fdetail%2F00050640.html&edit-text=
Press release
Released flagship of boss, effects processor which responds to professional guitarist's request
January 24, 2018 Tweetこのエントリーをはてなブックマークに追加
GT-1000 image
GT-1000 image
Roland Co., Ltd. will release the flagship model "GT-1000" for guitar effectors and processors that realized the highest level sound quality in the industry in April 2018 by the boss (BOSS) brand.
Image 1:
GT-1000 image
A floor type (floor-mounted type) guitar effect processor is used for many guitarists by expressive power that can produce various voices that combine multiple effects and the ability to switch timbres according to songs It is.
This time, "GT-1000" released at the heart of ultra-high speed custom digital signal processor (DSP) chips developed for music applications is the world's best as a floor type guitar effect processor of 32 bit / 96 kHz The sound quality of (*) realizes the overwhelming expressive power that could not be achieved with conventional models.
The guitarist's most admired amp sound is reproduced precisely by the new technology "AIRD (Augmented Impulse Response Dynamics / reading: Ayado)" which is specific to the tube amp strongly supported by guitarists by warm sound quality and comfortable response. Realistically express the subtle change in sound quality due to the operation of the amplifier circuit part to the input signal of the guitar and the electrical interaction between the speaker and the amplifier circuit. In the conventional model, when connecting to a guitar amplifier, the characteristics of the connected equipment influenced the sound quality and it was sometimes not able to obtain the intended sound, but "AIRD" is the characteristic of the connected guitar amplifier Optimally adjust the whole amplifier including up to. It realizes to obtain ideal amp sound in any environment.
The effect section has 116 kinds of boss's high-quality effects. From "OD-1", from historically highly evaluated models to new types based on "RV-500", "MD-500", "CP-1X", you can freely arrange your favorite effects You can make sounds.
"GT - 1000" is equipped with an XLR terminal that can send a signal directly to a live - house mixer etc. You can play with a comfortable sound even in an environment without using a guitar amp. Also, if you connect with a PC with a USB cable, it also supports digital recording using software such as recording. High-quality sound can be utilized in various environments.
The main body is equipped with 6 knobs and 10 foot switches. Users can freely register their functions, and can switch sounds and adjust them. Also, if you connect with a smartphone / tablet with Bluetooth (R), you can also make precise sound using the special application "BOSS TONE STUDIO" (iOS / Android compatible).
While the processor of the highest peak sound quality floor type guitar, "GT - 1000" is a design that eliminated exhaustion thoroughly and realized small size and light weight. From professional tours to recordings in the studio, from live houses and music production at home, they will be active in every situation.
As of January 24, 2018 ※. According to our company.
Product promotion video:
<Recommended for this>
· Guitarist · stage seeking the highest quality sound that is not satisfied with the sound quality of the floor type guitar processor which is currently used · professional level guitarist seeking the ideal amplifier / effect sound in any environment from the studio to the studio to the home
<This is the point>
· Newly developed custom DSP chip realizes the first 32bit / 96kHz high sound quality design as a floor type guitar · Effect processor · The latest technology "AIRD" optimizes the operation of the amplifier including the amplifier / speaker characteristics of the connection destination Adjusted to. Reproduction of sound of vacuum tube amp with realism that has never been before.
Name / product number: Guitar Effects Processor "GT-1000"
Price: Open price Release date: First calendar of April 2018 Number of units planned: 10,000 (domestic / overseas total)
■ Amplifier / processing with the highest sound quality The guitar amplifier using the vacuum tube is loved by many guitarists due to the warmth of the sound, the goodness of coming out, the loudness of the sound obtained when raising the volume, and the sound pressure feeling etc. . At Roland / Boss, detailed analysis is performed on each element of the vacuum tube amplifier, such as the operation of the vacuum tube circuit and the electric circuit reacting according to the input signal from the guitar, the interaction of the power amplifier section and the speaker, etc. Based on the technology and know-how gained there, the guitar amp "Blues Cube" and "WAZA AMP" guitar amp created by the original concept "Tube Logic" to design an ideal amplifier gained a high reputation for its sound quality and good response It is.
The amp section of "GT - 1000" was designed by the new technology "AIRD" born based on "Tube Logic". It is reproduced with the latest digital processing such as circuit operation inside the guitar amplifier such as a vacuum tube, the frequency characteristics of the speaker and the cabinet, and the electric influence that they have on the internal circuit of the amplifier. In an actual guitar amplifier, the speaker will electrically affect the operation of the amplifier circuit, so that a subtle change in sound quality will be born, but "AIRD" can express real interaction with this speaker Is possible.
There are many models that can obtain amp sound in internal processing with a processor of the floor type guitar, but in the model so far, since it is influenced by the sound quality by the characteristics of the guitar amplifier and the speaker of the connection destination, It was impossible to fully demonstrate its performance.
When connecting to the guitar amp "GT - 1000", just select the type of guitar amp to be connected with the "output select" function, the behavior of the whole amplifier is adjusted optimally. Regardless of the equipment to be connected, you can play with the ideal amp sound in any environment.
Amp type is equipped with 16 types, such as a popular model as a vintage model and original / amplifier assembled with boss's know-how. Especially, the amplifier designed by the original technology "MDP (Multi-Dimensional Processing)" which treats the sound optimally by dividing the sound into elements such as the sound range and the strength realizes the good response which can not be obtained by existing amplifiers I will.
["AIRD" logo mark]
■ Enjoying a versatile sound with a full boss effect, "GT-1000" has a boss effect that has been loved by guitarists for over 40 years. From the historically highly evaluated models such as "CE - 1" and "OD - 1", we have introduced "DD - 500", "RV - 500", which is popular for compressors and distortions that make use of "MDP" technology and even high - end guitarists, 500 "and" MD - 500 ", 116 types of high - quality sound effects are available. Up to 23 kinds of effects can be used at the same time and a wide range of expressions are possible. Parallel (parallel) connection of effects and sound making combined with external effects are also possible.
■ High freedom and easy-to-understand operation, "GT-1000" is also excellent in operability in cooperation with smartphones and personal computers. For the six knobs on the main unit, you can freely set the value you want to adjust, such as the degree of distortion (distortion) and the depth of the delay (echo). With 10 foot switches, you can flexibly set the functions according to the user's needs, such as switching timbres and turning on / off specific effects. In addition, LED indicators corresponding to each switch can also be customized by selecting colors with good visibility.
Moreover, it is possible to make precise sound making smoothly by using Bluetooth (R) to connect with smartphone / tablet and using the special application "BOSS TONE STUDIO" (iOS / Android compatible). BOSS TONE STUDIO (Windows / Mac compatible) can be used even with a personal computer connected with a USB cable. Furthermore, if you use the USB audio function of "GT - 1000", you can perform digital recording with high - quality guitar sound of 32 bit / 96 kHz.
The special application / software "BOSS TONE STUDIO" can be downloaded for free from the website "BOSS TONE CENTRAL" ( http://bosstonecentral.com/ ). Various styles of sounds are also available on the site, you can choose your favorite sounds and enjoy playing with "GT - 1000".
[Knob, switch function and LED color can be freely set]
["BOSS TONE STUDIO" (for personal computer) screen]
■ Product picture "GT-1000" image
"GT-1000" Front face
"GT-1000" rear surface
Dedicated software "BOSS TONE STUDIO" screen
■ "GT-1000"
External dimensions: 462 (width) × 248 (depth) × 70 (height) mm
Weight: 3.6 kg
※ Product images can be downloaded from the news release · page https://www.roland.com/jp/news/0787/ .
* For details of the product, please check at the boss · homepage https://www.boss.info/jp/products/gt-1000/ .
* Company names, product names, etc. in the text are registered trademarks or trademarks of each company.
※ Product information and release date etc. posted in this news release are information as of the presentation date. Please be forewarned that it may be changed after the announcement date.
※ Bluetooth (R) 's word mark and logo are registered trademarks owned by Bluetooth SIG, Inc., and Roland uses these marks under license.
■ Customer inquiries regarding products Roland Co., Ltd. Customer consultation center: 050-3101-2555
Quote from: Smash on January 24, 2018, 05:13:07 PM
Read the FX unit names in each block -
I see the following:
IN (Input)
FV (Foot Volume)
CMP (Compressor)
CHO (Chorus)
DIV1 (Signal Divider 1)
DIV2 (Signal Divider 2)
DIV3 (Signal Divider 3)
DS1 ( Distortion 1)
DS2 ( Distortion 2)
DS3 ( Distortion 3)
EQ1 ( Equalization 1)
EQ2 ( Equalization 2)
EQ3 ( Equalization 3)
EQ4 ( Equalization 4)
FX (FX Option )
FX1 (Effect Option 1)
FX2 (Effect Option 2)
FX3 (Effect Option 3)
EXT. FX Loop1
EXT. FX Loop2
AMP1 ( Amplifier 1)
AMP2 ( Amplifier 2)
DLY1 ( Delay 1)
DLY2 ( Delay 2)
DLY3 ( Delay 3)
DLY4 ( Delay 4)
NS1 ( Noise Supressor 1)
NS2 ( Noise Supressor 2)
S LR Out ( Sub LR Out)
M LR Out (Main LR Out)
MIX1 ( Mixer 1)
MIX2 ( Mixer 2)
MIX3 ( Mixer 3)
Rev ( Reverb)
M DLY (Master Delay)
Loop (38 second mono Looper)
MST ( Master Gain / EQ)
Smash
They seriously need to look at that signal chain screenshot and realise the potential here. Heads in fractal sand
hippietim
I remain optimistic, but I have to remind myself this is the company that thinks a JC-120 is good amp to play a modeler through
If6was9
Anyone paid attention to the synth-like sound at the end of the product promotion video? (2:04)
Quote from: If6was9 on January 25, 2018, 03:19:57 AM
Thats shimmerverb from RV-500 - included in GT-1000
If6was9
Redvers
If this had the gk guitar modelling from the gp-10 and  a midi soundset I'd buy it in a heartbeat. The mixing options and sub outs really solves a lot of love problems for me.
Smash
Quote from: Redvers on January 25, 2018, 04:26:32 AM
kind of a VG100 then....
Sevenmodes
The sub outs are long overdue and a welcome addition. It appears Boss has finally discovered XLR jacks... I can leave my stereo DI box at home now!
Having owned and gigged the GT-100 since it was released in 2011(?), I was starting to look to other options but I'm glad I held out. Even if they've only improved the amp models just a little, added RV, DD, MC effects and given us XLR outs it will still be a worthwhile upgrade.
The footprint appears to be slightly smaller as well, which means I'll have some room to shoehorn a few things into my ATA case for the GT 100.
hsuru4u
#40
sounds like crap to my ears. I mean 1k? really boss..599 would have been more realistic. If the gk stuff was onboard it would be way more interesting.I still like my vg8ex and vg99.The display on the gt-1000 is so 1990's with the big preset number. Better off to get the ax8 or helix lt.The helix verbs they released are very amazing as are the 2 new amp models. Line 6 really is supporting the helix well. If i had to buy 1 now it would be the helix lt. The ax8 display looks 1990's as well and no headphone jack or usb audio.Pass.I do like the fractal amp tones and effects but the interface is a turnoff. The boss just looks cheap.I use a gt-1 and for the 150.00 i spent its amazing.
I am kind of turned off by companies copying the helix floor unit [headrush anad now gt1000) and upping the pricepoint to match others.Just as the headrush i feel they overcharged for what it is. Again 499-599 would be more realistic for both HR and boss and would have likely sold/sell a ton more units. I hope the ax8 mk2 is a redone gui. And  the katana 100 and gt-1 pricepoints were genius by boss..but the gt1000 pricing is iffy to me.
The gt1000 may be ok for some but i am not likely what i hear from the demos.I know they have killer effects but something in the amp tones i am hearing just doesnt sit right.
mooncaine
Quote from: Smash on January 25, 2018, 05:01:52 AM
I was thinking more like a GT500. Without the awesome tuning & pitch control of a vg, it's just meh. :|
HecticArt
I still haven't seen enough of what it can do. Unless that's all it can do.....
For $1k I would expect more. It think we'll need to wait for some independent, in-depth reviews.
I'm still leaning toward the Helix. The latency makes me hesitate a little, and the $1500 does too.
If I can find a brand new one for around $1250, I'd probably go for it.
carlb
#43
What could tip the scales is if it sounds killer. Which it might. It's built on the architecture that goes into a Katana. And this one probably has four-times the GT-1 processing power and further-tweaked modeling - which is already good enough that I don't want to give up my GP-10 for an Axe-FX or a Kemper or what-have-you.
"Sounds like crap" are usually the tones that Boss's hired-guns go for: "Check out my 'chops-for-days! NURNH!'" Unfortunately, due to those same guys they're the tones that make it into the presets, too. Blergh.
Morningstar MC8 & MC6
QSC CP8 powered speaker
Smash
4 parallel chains - it's way ahead of the helix already! Way more possibilities.
I'm amazed there appears so much scepticism tbh - it's clearly got some of the Katana magic dns and Boss effects have never been any less than good.
I agree the demos are complete crap in terms of demonstrsting potential (what happened to Gundy? He'd have done a good job)- jeez the guitar is even out of tune in one of them but RV RD and RM built in plus those routing capabilities? It's easily at least equal to Helix
hsuru4u
I listened to choptones run thru at namm a bit. Sounds ok on the marshall he used but not like wow!!
I was a helix early adopter-like 1st week it was out-fw 1.0- and i returned it 2 weeks later as i thought it sounded like crap. I had a hd500 and sold it along with my dt25 years ago. I still have and use my spidervalve mk2 2-12 combo and think the tube power section is killer.
Not a fan of the boss demo guy at all. I think there is likely alot in there and will wait to see what tones are like. In no hurry and would even rather buy in a year or so when i can get a used one if need be. Same with the helix lt. I am leaning towards lt for interface and effects. I know that since my try on the helix years ago its been updated so i would have to buy it again and work with it for 2 weeks if i really want to.
As far as the katana and gt1000.I think its worlds apart in software as a guess. Like apples and oranges. To me katana has nothing to do with the gt1000 in any way or form. The gt-1 more so but they adverise that the gt1000 is a new standard in gt stuff so i dont think the gt-1 has the aird thing going on...and if it does its not advertised.
The beauty of the k100/head and gt-1 was the tone avail at that pricepoint. I get decent tones with each so for me to get the artist or the gt1000 isnt really in my game plan and would be silly for my needs. I was really hoping line 6 would release a 2-12 stereo combo helix amp with a tube power section.I know vox released the mv nutube combo and head but again soooo expensive its not on my radar.That too i will wait to see in another year or 2 where that goes with diff amps with effects onboard ect. Same with the yamaha thr100hd...That was a fail and just was not well thought out and way to high a price. I am waiting for the 2-12 stereo thr60 combo one day.
I am rooting for the boss but as a keyboard guy for many years the whole roland/boss mindset is way more technical and complicated then i could get along with.Just the manuals alone were just too technical for me.
hsuru4u
Quote from: Smash on January 26, 2018, 10:29:01 AM
i think the main issue people are having is the pricepoint compared to the gt100. Most were expecting a gt500 at 500-700.00 but like when the helix was released for 1500 people freaked out. Line 6 responded with the LT version at 1k. Good call for them.
The 4 parallel chains is cool and a wow factor on some levels for many who will use/need it but we dont know what the processor is and if it can handle those 4 chains bogged down without running out of space?. I dont care for the look as much as others may with the huge preset number but thats the way boss has always done it and always will. The gt-1 screen i like alot for what it is.Color isnt a big deal for me but its nice on the korg kronos i play. I think if it would be a touch screen people would be wowed more but the bluetooth edit is there for that realm and is cool for many guys.
we will see because in the end its the amp tones that rule. Boss already has good effects so i expect they will be plenty and good but will they exactly mimic the dd and other pedals 100%??? we will see. It would kill their sales of them if it did though.
HecticArt
At this point, the hangup seems to be that they didn't put the effort into a solid promo demonstration. It's hard to know exactly what it will do with the little that we've seen and heard. There may be a ton under the hood that will be impressive, but we won't know for a while. It's a missed opportunity to create a lot of buzz when something like this gets released. Time will tell.
Sevenmodes
The price point is directly related to the Helix LT obviously. If Line 6 can get $1k for their second tier product, the GT will sell just fine I suspect.
I would point out too that a lot of these modelers are sold to worship players/bands buying off a bigger budget. They've basically become an A/V expense for large churches and Line 6 and Boss are recognizing that.
My point of view... a few hundred extra bucks is a couple of gigs. Playing out doesn't pay my bills, but it supplements my budget for cool gear.
bond19
#49
Pre-ordered mine from L&M up here in Canada.  They said I should have it sometime in March.  Currently using a GT 100, but before that I had a HD500X, before that a Line 6 Firehawk FX, before that a GT-10, and my first multi effects was a GT-5.  To me the GT 1000 looks like it will incorporate some of my favourite features from my past multi effects units- bluetooth connectivity, xlr out, low latency, along with all the new goodies.  I am planning on re-creating my current GT 100 patches on the GT 1000, and will likely post findings, so for me, I am superstoked! Footnote- Boss did an excellent job of keeping this secret, I thought this was a hoax when I first saw it a few days ago, but as it sunk in, I knew I had to pull the trigger on one.
