RR GC-1 can you wire the mag pickups to the 13 PIN?
Started by davang55, December 19, 2017, 06:38:26 PM
davang55
Thinking about picking up a used RR GC-1 to have a strat again. I like the way the Godin Nylon SA and xtSA can connect to the GR-55 effects on the regular pickups but I was told the mag pickups on the strat only go to the 1/4" jack.  Is that true?
Is there a mod to jump a wire to the 13 pin?
Jeff
davang55
OK I did some research on the Forums here and found that the normal mag pickups of the RR/GC-1 strat  DO go to PIN 7 of the 13 pin connector just like the Godin xtSA.
Correct?
DeRigueur
I don't know about the pin assignments, but the gc1 has the "standard" 3-way switch that allows for GK, mags, or both.
Quote from: davang55 on December 19, 2017, 06:38:26 PM
Jeff
Correct?
Correct!
The RR Strat / GC-1 does provide a path for the normal Mag PUs over Pin #7 of the GK 13 pin cable
Here is the GK-2A Schematic - This is very similar to the same basic signal flow as the RR Strat / GC-1
davang55
Yes, I have seen that and am aware of the need to assign the normal pickup to the "ON" position for each patch. Thank you for the heads up. I don't do  real complicated set-ups, just like o have a pad or strings with my acoustic guitar. I play at church and the piano player is strictly acoustic has no idea about keyboards etc. so it's up to me to bring them kicking and screaming into the modern music world.
Sometimes i use the xtSA when i need a warmer guitar or need to play more melodic stuff, but I'd prefer to have a strat to do that. was gonna change the neck out to a wide warmoth style to approximate the feel of the acoustic guitars wide neck.
I wish there was a way to use the tone controls to affect the gk pickup...
