GP-10 - Are CTL/GK/EXP setting only global?
Started by JazzGuiutarGimp, September 18, 2017, 12:09:56 PM
JazzGuiutarGimp
Hi,
I did some patch creation on GP-10 last week, and wound up chasing my tail for a few hours, thinking the CTL/GK/EXP page in the editor uses per-patch memory. I'd start a new patch, make a change in the CTL/GK/EXP page, only to find my other patches no longer worked the way I had set them up.
Am I correct in assuming the settings in the CTL/GK/EXP page are global, or common to all 99 patches? If so, is there a way to make this group of controllers work with different settings for each patch?
Many thanks,
Lou
You can set it per patch or globally
QuotePedal and Switch Settings for Each Patch (Ctl: )
For each patch, you can individually specify the functions that are assigned to the [CTL 1], [CTL
2] pedals and the expression pedals. If you want these pedals to always have the same function
regardless of the patch, you can specify this using the system setting "Sys: Controller" (p. 13).
* This is available if the Sys: Controller (p. 13) is set to "PATCH SETTING."
