MIDX-10 Its here!
Started by Bill Ruppert, November 14, 2015, 06:40:21 PM
kenact
Quote from: Elantric on November 29, 2015, 08:25:03 PM
We only recommend the newer UM -ONE MKII
I have a UM-1ex, and about 7 different PCs, all running Windows 10 x64. The UM-1ex runs on some, but not others.
I'm going to try something funky. I've copied all the Registry entries from a PC where it works, and I'm going to import them to the registry of a PC where it doesn't work.
I've also copied all the inf, dll and exe files.
I'll let you know how I make out.
Danoblaster Baritone w/GK-3
Gretsch Nashville, Viking
Fender Strats
Fret King Supermatic
Larrivee DV03RE
Parker Midi Fly
Seagull, S&P 12
VOX Phantom XII
Sentient 6
Cyr 7
Quote from: kenact on October 27, 2020, 03:49:24 PM
Interesting, I guess some Windows PC's have different USB chipsets which might not be compatible,
have you tried the UM-One DIP switch in the 'other position'?
Copying Windows Registry entries from one computer to another...
kenact
Quote from: gumtown on October 27, 2020, 04:19:05 PM
There are only 2 switches, the Advanced Driver and the Midi Thru. Even when I used it on Windows 7, the Advanced Driver switch didn't work in the ON position.
Fortunately, my guinea pig computer has the same user name as the computer I exported the registry entries from. That's important because some of the registry entries reference the user profile.
I'll report back soon.
Fender Strats
Larrivee DV03RE
Parker Midi Fly
Seagull, S&P 12
VOX Phantom XII
Sentient 6
Cyr 7
If your computer has a mix of USB 3.0 and USB 2.0 ports  - always use the USB 2.0 ports 1st for UM-ONE MKII connections
many USB 3.0 chipsets do not support USB Audio / MIDI devices properly ( intel)
Windows PC USB 3.0 compatible chipsets for Audio Interfaces
https://www.vguitarforums.com/smf/index.php?topic=8562.0
Quote from: kenact on October 27, 2020, 06:13:27 PM
In the "Advanced driver On" position, the UM-One uses the downloaded Roland USB midi device driver (for Windows 7, auto install on Windows 10),
and the "Advanced driver Off" position makes it run as a USB class compliant device.
You do need to unplug the USB device before changing the DIP switch position.
kenact
Oh well. :(
Time to try another tack.
I exported every registry entry that referenced UM-1, all 32.
I created any missing registry keys, and imported all the entries I exported.
I created the missing FileRepository folder, and restored all the files from the working computer.
Searching through the Registry, it appears I may have some remnants of a previous attempted install. I may have to carefully go through and remove all UM-1 references and give it another go round.
More to follow.
Fender Strats
Larrivee DV03RE
Parker Midi Fly
Seagull, S&P 12
VOX Phantom XII
Sentient 6
Cyr 7
