JTV - All three Pups at once?
Started by Tapper Mike, November 03, 2016, 09:21:59 AM
Tapper Mike
Hi,
I'm trying to recreate the Peter Frampton Custom LP.   Unlike other custom LP's the Frampton has a middle position where all three pickups at the same time.  No matter what I do I can only link two pickups per position.
-Thanks
Mike
gmrizzo
You can do it blending one virtual middle pickup with both mags at the JTV 59
Just build the LP with middle PU in workbench HD with mags vol mix set to 50% and be sure to assign this model to position 3.
So when you select it you will have your two mags blended with the virtual middle PU, at a 50/50 level
Tapper Mike
I borrowed a little bit from your idea.  I don't have a '59 I have a Yamaha Variax Standard.  What I did is used position 2 on the standard combining middle and bridge magnetics... Then moved the bridge pup on Lester to the middle position and combined it with the neck position Lester.
gmrizzo
Glad you took it from there and got the adaptation for 3 pups.
The possibilities are endless
