Bright Onion Pedals - Kat Preset Footswitch
Started by admin, January 25, 2018, 11:15:55 AM
http://www.brightonion.co.uk/katana-preset-footswitch/
Kat Preset Footswitch - Preset switcher for the Boss Katana Amps - Bright Onion Pedals
The kat preset footswitch is designed to be used with the Boss KATANA-50, KATANA-100, KATANA-100/212 and KATANA Head amps that have firmware 2 onward.
The footswitch let you switch between the amp presets 1A, 1B, 2A and 2B.
A TRS ¼" cable is required to connect the footswitch to the CH1 CH2 foot control socket on the rear on the amp, you can add a Bright Onion TRS cable to the order above, the cables are built using Van Damme cable and Neutrik Rean straight plugs.
The pedal is active so requires power, you can add a battery to the internal clip or use the Boss style 2.1mm 9v (negative ground) DC socket using an adapter (not supplied).
The pedal is built with:
•    Aluminium enclosure
•    Neutrik jack sockets
•    Heavy duty soft touch footswitches
•    LEDs
•    2.1mm 9v DC Socket and internal battery holder
•    Velcro to stick it to your pedalboard
Enclosure dimensions:
120x95x34mm
