GP-10 BACKUP
Started by alexmcginness, June 10, 2016, 04:21:26 AM
alexmcginness
Hi, is there a function in the GP 10 to do a complete memory dump/backup like in the VG-99?
   Id like to be able to do some sort of dump for the GK settings and patches so I can load different settings for different guitars and projects.
47Flyer
I don't have a VG99 so I'm not completely familiar, but I do have a VG-88 and GR-55 which allow you to dump and load through the midi ports.  The GP-10 does not have midi ports but it does have a USB capability which allows you to connect the GP-10 to your computer and use the BOSS Tone Studio software to save your current set list and then load a previously saved set list.  This is how I use it.  Just be careful using the Boss software as it tends to reset some parameters when backing up to the computer.  The entire process only takes a few seconds.
Kevin M
You can use the USB interface and do a sysex dump.
QuoteYou can use the USB interface and do a sysex dump.
How?
Boss wants you to use Boss Tone Studio for GP-10 (Win/Mac),
https://www.vguitarforums.com/smf/index.php?topic=17630.0
One of the "joys" of GP-10 not having MIDI I/O jacks is the GP-10 lacks the old school  "MIDI Sysex Dump"  function found in older Roland VG  / GT  / GR gear.
And this specific issue might have been a major part of Roland's design decision to remove the 5 pin DIN MIDI I/O Jacks from the GP-10 . Many forget the "bricked" Roland VG-88 V2 upgrades, due to the wild variability of MIDI hardware interfaces, and a full GP-10 MIDI sysex data dump would be prone to dropped data with most 5 Pin MIDI interfaces out in the wild today.
Like this popular (p-o-$) below  that does not even have an opto isolator to meet the MIDI Spec
http://www.arvydas.co.uk/2013/07/cheap-usb-midi-cable-some-self-assembly-may-be-required/
Removing the MIDI I/O jacks has benefit of ceasing product support calls too .
Latest BTS Version has an Off-Line Mode, so you may open any GP-10 patch we have shared.
The Official Boss GP-10 MIDI Spec is the most clear / literate version ever released - worth reading
https://rolandus.zendesk.com/attachments/token/9DpnoVeDSj9pFGUAepOpoTthq/?name=GP-10_MIDI_Imple_e01_W.pdf
alexmcginness
Quote from: Kevin M on June 10, 2016, 09:25:29 AM
  Im all ears. How do I do that?
VGA-7
Open Tone Studio ,librarian and Backup button at the top .
Gibson L6S /gk2a , Bradley mini strat  /gk2a VGA-7 amp ,GR-33 , GP-10,SY1K, RMC breakout box, PK5 midi pedals,CM-64 sound module, Oberheim EDP  ,Boss RC-300,Digitech TRIO and TRIO +, Alesis DM5, GX2 Gear Shifter and GKPX-14
alexmcginness
Quote from: VGA-7 on June 10, 2016, 08:45:53 PM
  I dont think this grabs the GK setup and system settings.
alexmcginness
need to take a screen grab and manually input GK and system settings. Small price to pay for the portability and a great editor.
Quoteneed to take a screen grab and manually input GK and system settings. Small price to pay for the portability and a great editor.
Yes - that appears to be the case with GP-10 - no way to backup the System User settings
Quote from: Elantric on June 11, 2016, 09:09:49 AM
But also no way to accidently overwrite the user settings.
