GR-55- Exp pedal question
Started by chrisnickey64, August 20, 2017, 01:14:01 PM
chrisnickey64
Just bought a gr55 and a roland strat. I was wondering if it's possible to to use the expression pedal to move back and forth between say acoustic guitar  patch and string patch . So i can fade out the strings when i want or fade them in and blend with the guittar .  Can the exp pedal be assigned like that? Thank you
 Read the GR 55 FAQ
specifically read about GR-55 multi sound patch creation
* GR-55 Ultimate Multi Control patches (solves the GR-55 long Patch change delay (with mute) issue)
and
Jim Williams Multiple Assignment Patches.
https://www.vguitarforums.com/smf/index.php?topic=5647.msg38806#msg38806
Learn multi-assignments by following all steps outlined here - then edit to suit YOUR needs.
Guitarplayer_10's  GR-55 Ultimate Multi Control patch step by step
https://www.vguitarforums.com/smf/index.php?topic=7267.msg50612#msg50612
GR-55 - Use all four GR-55 tone sources mixed via Expression Pedal position
https://www.vguitarforums.com/smf/index.php?topic=9591.msg151708#msg151708
Toby Krebs posted dozens of GR-55 patches he uses at his gig. Each patch uses Multiple Control Assignments for the Expression pedal to allow you to "pan" between rhythm and solo tones withing each patch  - this allow you to use One GR-55 patch per song and circumvent the long mute silence gap that occurs when changing GR-55 patches during a song.
https://www.vguitarforums.com/smf/index.php?topic=8709.0
Yes.
You can cross fade between different tone sources, such as acoustic modelling and a strings PCM synth tone.
