Large list of free VST plugins and utilities
Started by lespauled, February 07, 2015, 06:10:43 PM
Now_And_Then
Kenmac
Just thought I'd let you know that Surreal Machines is offering the Diffuse Delay effect, which regularly sells for $49.00, in VST/AU plugin formats for PC and Mac as a completely free download from their website until June 8th. Here's some information about it:
Diffuse is an analog/digital hybrid – an analog modeled delay fused with a classic reverb design used in early digital units. It's focused on the sound of classic hardware delay and reverb units of the 1970s and 1980s. In Diffuse you get more than the best of both worlds – you can morph between delays and reverbs, and find all kinds of fantastical sounds in between the two. You'll also find plenty of nonlinearities and smooth tape-style delay changes. Diffuse gives you complete control over smearing, echoes and damping in the most intuitive ways possible.
The interface is organized into three control groups. The knobs on the left control the volume and the stereo width, the centrally positioned knobs control the delay time, feedback, and diffusion parameters, whereas the knobs on the right control the tone, modulation, and mix level. It is also possible to A/B test different settings, lock the mix level parameter (probably intended for live performances), and save presets internally for later use. The plugin includes a decent selection of factory presets to help new users get started.
If this sounds interesting, you can download your free copy of Diffuse Delay on the product page linked below. Your serial number will be delivered via email as soon as you register. To activate the plugin, copy your serial number and click the plugins user interface on first startup (it will detect the serial number and activate your license automatically).
NOTE:
You have to copy something like this to your clipboard: START|Firstname Lastname|example@gmail.com|#### ####-####-####|END
If you only copy the parts between START and END, or just the #### portion, it won't work. It kind of threw me the first time around as I was just copying the serial number.
I've been trying the plugin this weekend and it's just mesmerizing. If you're into ambient/experimental guitar you'll really enjoy it.
Here's the link: https://www.surrealmachines.com/product/dub-machines-vstau/  It's on the far right side of the website.
ffata
Thanks for this info.
I just dl'd it and I'm trying it out with lotsa tracks in Logic 9.
This almost falls into the land of OhmBoyz!
Thanks, again
Kokopelli
mummer
Kenmac
You're welcome everybody. I'm hoping that aliensporebomb checks out this thread as this plugin seems like it would be right up his alley.
slooky
Kenmac
Installing this now!  Thanks for the heads up!
Kenmac
You're welcome Todd. Funnily enough I was using this plugin again last night and I was trying out the "Hold" function which, not surprisingly, acts just like the freeze function on the VG-99. Check it out and have fun.  :)
BackDAWman
Quote from: Now_And_Then on February 07, 2015, 10:15:06 PM
Behold a larger list:
http://web.archive.org/web/20120912053655/http://plugins.gersic.com/index.php?daCat=-3
Reaper DAW will automatically bridge 32 and 64 bit plugins, it is the only DAW that I know that will do this without JBridge.
http://www.bluecataudio.com/Products/Bundle_FreewarePack/
http://www.gvst.co.uk/downloads.htm
http://bedroomproducersblog.com/free-vst-plugins/
Cubase did this up until the last version of Cubase Pro 9. If you have this version use 64bit only or you'll get a lot of crashes if they work at all.
DreamTheory
Sylvia001
 ;DI am looking for this .Thanks for the post.
It's easy to find FREE VSTs...
It's hard to find GOOD free VSTs!
BackDAWman
There used to be a great free delay VST plugin called Reorder (I think that's right). I haven't seen it for years. It slices your audio up and then re orders the slices rhythmically. It was VERY useful.
Anyone heard of it or know where I can get it?
lespauled
Quote from: BackDAWman on November 08, 2017, 03:09:23 PM
One of these?
http://www.vst4free.com/index.php?plug-ins=Loop/Scratch&l=5
http://www.harmonycentral.com/news/how-about-a-free-tremolo-and-auto-pan-plugin
HY-Plugins and BPB release free HY-TP2 tremolo VST/AU plugin
HY-Plugins and BPB have released HY-TP2, a freeware tremolo and auto-pan effect in VST and AU plugin formats for compatible digital audio workstations on PC and Mac.
ABOUT
HY-TP2 is an updated version of the HY-TP tremolo effect by HY-Plugins. The new version of the effect comes with an improved user interface and a slightly modified feature set. HY-TP2 includes two additional LFO shapes while removing the envelope follower and soft clipper functionalities found in its predecessor. The LFO module now also features a phase shift knob for precise timing adjustments.
The Mod Wave section includes the LFO waveform selection panel (sinewave, triangle, ramp up, ramp down, log up, log down, square, and random), a phase adjustment knob, and a smoothing knob which smooths out the shape of the selected waveform. The Tremolo/Panner section features the modulation rate, modulation depth, and modulation width knobs. The width knob affects the plugin's behavior as a tremolo or a stereo auto-pan effect. The filter section features a pair of filters (low-shelf and high-shelf). Finally, the Output section features the output volume dial.
FEATURES
LFO module with 8 waveforms (sinewave, triangle, ramp up, ramp down, log up, log down, square, and random)
Waveform smoothing and phase
2 tone filters (high-shelf and low shelf)
Adjustable modulation rate and depth
Patch manager
Undo/redo functionality
Randomization functionality
Resizable user interface
SYSTEM REQUIREMENTS
Windows: Windows 7 or higher (32-bit / 64-bit)
OSX: OSX 10.8 or higher (32-bit / 64-bit)
LINKS
HY-TP2 (product page)
Demo video (YouTube)
slooky
https://www.spitfireaudio.com/labs/
Frozen strings,synth pads,choir,charango,electric piano,amplified cello quartet, drums,strings, soft piano  all Free
