VB-99 cheap mic stand mount
Started by ficelles, October 01, 2022, 06:05:41 AM
ficelles
... actually it's a Roland MDP-7 drum pad mount with a mic stand thread adapter screwed into the top, which with the MDP-7 being plastic is quite easy.
TrainWreck
Great idea.
Can you show or describe how the MDP-7 interfaces with the mic stand with the threaded adapter?
ficelles
Quote from: TrainWreck on January 21, 2023, 12:25:49 PMGreat idea.
It just screws on like a microphone clip, once you have added the thread adapter. Here's a pic with one in the base (I had to use a reamer to widen the hole a little to get the adapter to screw in):
Use the provided Roland MDP-7 drum pad mount with a mic stand thread adapter
Or
Botton post on MDP-7 mounts to a common Drum Stand
https://www.amazon.com/Gibraltar-6713E-Double-Electronics-Mounting/dp/B00HX9F1OQ/ref=pd_aw_fbt_vft_none_img_sccl_1/131-7961144-7259116
Alternative to the Roland  PDS-10 Stand
https://www.vguitarforums.com/smf/index.php?topic=1078.0
