Optimal USB settings for recording using USB
Started by ILIADE, August 19, 2022, 08:14:06 AM
ILIADE
Hi everyone,
I own a SY-1000 and GX-100. I normally use the audio output from these devices connected to my NI audio interface for recording (I use Logic Pro X). I recently tested recording using the USB out and was wondering what are the optimal settings? The owner manual are not really useful since there is no recommendations for output level or any other settings using the USB output. Thanks for your help!
Chris
Set the usb out level to normal recording setting -2 to -6db in logic.
Set the usb in level ( for monitoring logic not SY-1000 ) to what you feel is a good volume to play to. Direct monitoring from SY
Set audio routing to standard. ( and normally that also includes main out )
cafeTechne
I'm having good results with at 48khz , 64bit buffer size (for reduced latency) on a a 2021 M1 mac.
