can i use preamp with my fender blues deluxe 4 cables?
Started by mantra, May 03, 2022, 02:13:27 AM
mantra
Hi
can i use a preamp when i use my tube fender blues deluxe 4 cables?
i really like the boss gt-1000 RECTI STACK preamp  distortion
I would like to use the preamp distortion of RECTI STACK preamp , can I?
and is there a sense ?
I mean i don't want to use an extra active speaker but only my amp
thanks
QuoteRECTI STACK
Models the sound of the Channel 2
MODERN Mode on the MESA/Boogie
DUAL Rectifier.
Boisdelac
4 cable methode means
guitar -> input multi effects ("pre effects" wahwah, distortion, modulation eq, compressor etc.) -> multi effects send -> guitar input fender blues deluxe amp (preamp amp) -> fender blues deluxe send -> return multi effects -> ("post effects" delay, reverb, modulation, eq, noisgate etc.) out multi effects  (output select to tube combo 112) -> input poweramp fender blues deluxe -> speaker
Instead of using the fender blues deluxe´s internal preamp use the GT1000 AIRD preamp
Guitar -> input multi effects ("pre effects" wahwah, distortion, modulation -> AIRD amp (Rectifier model) -> ("post effects" delay, reverb, modulation, eq, noisgate etc.) out multi effects (output select to tube combo 112) -> input poweramp fender blues deluxe -> speaker
Set the output selection as desired. Try also different settings than tube combo 112.
