How do I import audio files in sync to RC300?
Started by Gearvfeel153, March 23, 2022, 01:20:02 AM
Gearvfeel153
How do I import audio files so that the original tempo of the audio file is recognised and used by the RC300?
I am having a problem with with importing audio files into the RC300.
The tempo in the finished loop is not the same as the original tempo of the import file.
I created the files in Logic Pro. I then exported them and converted the audio files to AAC and/or Apple Lossless, then again converted them to WAV. I also trimmed the audio to exact bar length for a loop.
I have tried importing them into a completely empty memory on the RC300.
I have tried importing them into a memory on the RC300 that has the same tempo saved and on each track I also set the exact amount of bars of the imported audio.
None of this works and I end up with a completely different tempo. If I try to adjust the amount of measures afterwards or the tempo, the RC300 alters the pitch of the audio and the original tempo also changes.
I feel as though there is going to be a simple solution to this, but I haven't been able to figure it out myself.
So any helpful advice would be really welcome!
