how can i set the delay time with delay tap accel ctrl ?
Started by mantra, March 22, 2022, 11:59:44 PM
mantra
Hi
there is a limit for tap tempo and it's 250 , and it easy to setup
but about delay tap , it does not work , let say I would like to tap delay time at 677ms , can i do it with DELAY TAP ?
I can set the tap tempo with this setting
but i can not change delay time with delay tap with accel/Ctrl
I can tap accel/Ctrl but it does not change the delay time
may i know why?
thanks
Boisdelac
What Kind of gear are you using. Does the picture show a GT1000 tonestudio?
To use TAP time, the Delay Time must be set to a Division Rate instead of a fixed Time.
Turn the Rate knob all the way up to find the time divisions, and Tap tempo will work, typically "Quarter Note"
Also the Pedal function for DELAY TAP or BPM TAP the Source Mode should be "Moment" (not toggle)
mantra
Quote from: gumtown on March 23, 2022, 03:04:22 AM
Hi
yes ,works perfecly
thanks Gumtown
