Ableton Live 9 & Push - out now
Started by MCK-fgn, March 06, 2013, 09:08:35 AM
MCK-fgn
New version out. Interesting new hardware controller.
Zummooz-fgn
Cubase and Ableton ..... come on Logic
It must be just me ...
But for some strange reason, I just can't get the grip of Ableton, i've tried and tried.
Just something about it ...
So I gave up ... ::)
I've used other DAW's too, but keep going back and using Logic & Cubase, mostly Logic.
Suppose it depends what you like / how you work and your own setup and what you have toy wise.
Elantric-fgn
I just upgraded to Live 9, with a Push arriving in 12-16 weeks.
Ableton Live is not like any other DAW, but once you get into it, it is the right tool for flexible live performance  / and looping today  - its not just for DJ's
dalai_llama-fgn
Quote from:  Elantric on March 07, 2013, 11:40:16 AM
Ableton Live is not like any other DAW, but once you get into it, it is the right tool for flexible live performance  / and looping today [...]
+1! Live has its own logic (pun intended!) Very much unlike other DAWs. :)
I've been using both for years now, and I agree with you: Live's low memory usage and flexibility are just great. There are ups and downs to both Logic and Live, which I posted in greater detail in other forums but can't find that to repost here. I can go deeper into the topic if need be.
That being said, the implementation of midi in Logic 8 and greater versions is lacking, but Ableton Live is even worse. To use midi guitar, at times you have to be very creative and use some serious workarounds. Live filters Program Change messages in all channels but 1. So you have to multiply your midi ports and transmit each port on channel 1 to get all 6 strings to perform correctly. :-\  And that's just one, there are others...
