Simple 3 channel mixer recommendations?
Started by MCK-fgn, May 07, 2010, 06:01:45 AM
MCK-fgn
Hi, quick question for all of you in the know! I need a simple 3 channel stereo mixer to mix the VG99/VB99/GR33 trio down to one stereo signal so I can feed it into a stereo looper. I will use the sub-outs to go to the mixing desk so I can still record each individual sound separately but for the looper to loop on whichever device I have going (via SGUS-3) I need a combined signal. I need something compact and very simple. 3 input, 1 output + 3 adjusters will be all I need really. Any ideas? Thanks much in advance.
Elantric-fgn
MCK-fgn
Super! Thanks much for that. Should very nicely do the job! Appreciated.
MCK-fgn
I will also need 1 TRS to 2 TS cables to go with that... Actually they will cost more than the mixer but hey as long as it works... Let me go shopping!
MCK-fgn
While waiting for the small mixer it just dawned on me... I have a JamHum GreenRoom at home and it can very well do the job in the interim! Great!!! Only shortcoming is that the GR33 has only one set of output unlike the VG99... I will have to figure out an alternate approach to branch off GR33...
wootzy
Quote from:  MCK on May 11, 2010, 03:15:15 AM
Maybe you could use an other one of these split/mixer to split the signal :)
wootzy
On a second note, you might be settled for both applications with this little device.
Taken from http://www.proaudiosystems.co.uk/product-3500-5-39-37/mixers/art-splitmix4-four-channel-passive-splittermixer.html
"Mix 4 stereo input channels down to 1 stereo output, split a stereo input signal to distribute 4 stereo output channels, or combine the configurations for a wide range of applications."
MCK-fgn
Not sure if it can do both at the same time. That would be amazing if possible. We'll see soon. Thanks for your help.
