GT-1BFxFloorBoard patch issue
Started by MrClóvis, May 09, 2021, 03:00:03 PM
MrClóvis
Hello!
Today I reserved an hour to create a new patch using the amazing GT-1BFxFloorBoard. Everything works well, also after taking a few days to study the plugins' role I managed to reproduce sort of the ideas inside GT-1B.
Also I've been using it past a month now, it did create three patches, but here is the situation:
I saved the patch via hardware — tapping both hardware buttons and then writing it down. The patch then saves, but I can't edit from software anymore, seems like unrecognizable.
Side note, FxFloorBoard loads and read other patches. Here is the returning message — see attachment; whenever I click the patch name inside FxFloorBoard.
That is unusual, is there anything out of the ordinary with this patch settings/parameters ?
what if you save it on the GT-1B to another duplicate User patch location,
does the patch copy exhibit the same problem?
MrClóvis
Sincerely, from the parameter perspective I've assigned the same as the other patch from last week.
A few minutes ago I copied the patch to a new entry, respectively from U4 to U7. Tone Studio reads both, however FxFB still can't recognize U4 and U7.
Could you pleas make a copy of the patch with tone studio and post it here. I will load it into my GT-1B and see what is going on, and look at fixing GT-1BFxFloorboard.
I have never known any Boss device to have a patch with different sized data from another patch on the same device. Maybe it is something elese causing that issue, but if I can examine the patch to see what's up.
