katana mk2 foot switch
Started by snarph, April 03, 2021, 02:25:17 PM
snarph
what foot switch or controller can be used with a katana 50 mk2
Welcome to the group snarph!  :)
Quote from: snarph on April 03, 2021, 02:25:17 PM
the Roland FS-6L DUAL Latching  footswitch is listed in the Katana MKII  manual
toggles between CH A / CH B  and Bank Up/Down on Katana 50 MK2
or any Dual Latching Footswitch with TRS CABLE
snarph
so toggling  between CH A / CH B on Katana 50 is as good as it gets for the 50mk2 ?
Quote from: snarph on April 04, 2021, 07:46:13 AM
Rtm
Or use a MIDI Foot controller with this necessary converter
http://www.primovasound.com/midx_20.html
Or Raspberry Pi or Teensy 3.6  SBC and coding
https://www.vguitarforums.com/smf/index.php?board=240.0
Or upgrade to the 100 watt Katana models with their superior footswitch control and support for GAFC
Head includes MIDI Input for a foot controller
The Katana 50 model has only 4 channels, selectable with a dual foot switch,
the Katana 100 watt models have 8 channels, using a dual foot switch can access the first 4 channels,
but the 100's also can use the proprietry Boss GAFC pedal which accesses 8 channels + Panel channel, and effect switching.
The 50 does not have a GAFC port (digital interface)
sikejsudjek
#6
I've finally worked out that if you plug one expression pedal into the back of the amp and the other expression pedal into the gafc - that leaves a free input on the gafc to put a non latching switch. That can be assigned to switch the pedal fx on or off. That means I don't have to assign the fx to pedal fx - and can use it for something else like octaver etc. So now I have one foot pedal controlling volume, one foot pedal for pitch shift or wah, and a non latching switch into the gafc to switch on the pedal fx.
This works on my mark 2 artist, not tried it yet on my mark 1.
