Katana 100 MK1 aux input to S/R
Started by Cian, June 19, 2023, 07:21:37 AM
Cian
Hello! Does anyone know if it is possible to get input from the aux input into the FX loop on the katana? The use case is something like a backing track being fed to the aux input and a looper in the S/R. Audio from aux in is captured by the looper in the FX loop. Is it possible? Have tried several combinations and settings in tone studio but have yet to get it to work
Not possible due to hardware topology
you will need a 2 channel mixer, or A/B switch, into the looper input, with the Katana send into channel 1 or A input, and the Aux tone source into channel 2 or B input.
Probably an A/B switch would be better so you can select the tone source (guitar or external) to loop.
