MIDI Program Changes
Started by Antonuzzo, December 08, 2020, 12:08:01 PM
Antonuzzo
I've got a Roland VGA-3, and I'd like to control it with the Helix via MIDI.
The VGA-3 has 40 presets, but only 10 are accessible from the front panel; the others need a foot controller. This would normally be the Boss FC50 / Roland GFC50, but I wondered if I could set my Helix up to tie a preset on the VGA to a preset on the Helix?
Can't see any reason why not,
it should be straight forward to setup in the Helix Command center, a midi program change to send when a particular Helix patch is selected.
Boisdelac
Maybe your VGA-3 uses a combination of MIDI PC# and MIDI Bank selects
If it is similar to the GT1000 ....
Select sound  1...10 send Bank select 0 and PC# 0...9
Select sound 11...20 send Bank select 1 and PC# 0...9
Select sound 21...30 send Bank select 2 and PC# 0...9
Select sound 31...40 send Bank select 3 and PC# 0...9
Bank select is realized as a combination of sending two MIDI-CC#
To select Bank 1 send CC# 00 00 and CC# 32 00
To select Bank 2 send CC# 00 01 and CC# 32 00
To select Bank 3 send CC# 00 02 and CC# 32 00
To select Bank 4 send CC# 00 03 and CC# 32 00
