Steinberg- Cubasis 3 for Android
Started by admin, June 15, 2020, 05:40:26 PM
http://www.synthtopia.com/content/2020/06/15/steinberg-cubasis-3-now-available-for-android-devices/
Steinberg Cubasis 3 Now Available For Android Devices
Steinberg has released Cubasis 3, a mobile DAW originally introduced for iOS in 2012, in a new version for Android devices.
Cubasis is designed to let you perform, record, mix and share music from your mobile device.
Features:
Unlimited number of audio and MIDI tracks
32-bit floating-point audio engine
Audio I/O resolution of up to 24-bit/48 kHz
Real-time time-stretching and pitch-shifting featuring zplane's élastique 3
Micrologue virtual analog synthesizer with 126 ready-to-go presets
MicroSonic with over 120 virtual instrument sounds, from acoustic piano to an array of drums
MiniSampler to create your own instruments, including 20 factory instruments
Mixer with studio-grade channel strip per track and 17 effects processors
Master Strip plug-in suite with exceptional great effects
Fully automatable DJ-like Spin FX effect plug-in
Over 550 MIDI and timestretch-capable audio loops
Virtual keyboard, chord and drum pads with intuitive note repeat
Audio editor and MIDI editor with MIDI CC support
MIDI editor for programming and editing MIDI tracks quickly and efficiently
MIDI auto quantize
Track duplicate
Automation, MIDI CC, program change and aftertouch support
Audio and MIDI-compatible hardware supported*
MIDI clock and MIDI thru support
Export to Cubase, Google Drive, external hard drives, wireless flash drives, Dropbox and more
Pricing and Availability
Steinberg Cubasis 3 for Android is available now for $49.99 US
https://play.google.com/store/apps/details
Quickly and easily capture your musical ideas as soon as they arrive and turn them into professional-sounding songs with the multi-award winning Cubasis 3. Enjoy performing, recording, mixing and sharing your music in no time, wherever you are, right there on your smartphone and tablet. Meet one of the fastest, most intuitive and complete audio and MIDI DAWs available on Android today: Cubasis 3.
Learn more about Cubasis at www.steinberg.net/cubasis
HIGHLIGHTS
• Unlimited number of audio and MIDI tracks
• 32-bit floating-point audio engine
• Audio I/O resolution of up to 24-bit/48 kHz
• Real-time time-stretching and pitch-shifting featuring zplane's élastique 3
• Micrologue virtual analog synthesizer with 126 ready-to-go presets
• MicroSonic with over 120 virtual instrument sounds, from acoustic piano to an array of drums
• MiniSampler to create your own instruments, including 20 factory instruments
• Mixer with studio-grade channel strip per track and 17 effects processors
• Master Strip plug-in suite with exceptional great effects
• Fully automatable DJ-like Spin FX effect plug-in
• Over 550 MIDI and timestretch-capable audio loops
• Virtual keyboard, chord and drum pads with intuitive note repeat
• Audio editor and MIDI editor with MIDI CC support
• MIDI editor for programming and editing MIDI tracks quickly and efficiently
• MIDI auto quantize
• Track duplicate
• Automation, MIDI CC, program change and aftertouch support
• Audio and MIDI-compatible hardware supported*
• MIDI clock and MIDI thru support
• Export to Cubase, Google Drive, external hard drives, wireless flash drives, Dropbox and more
MORE GREAT FEATURES
• A brand-new Cubasis: The next generation mobile music creation app
• Universal handheld support: A feature-rich DAW which runs on your smartphone and tablet
• Cubasis for smartphone: Make great music in the palm of your hand
• Group tracks: Easily combine individual tracks to groups
• Full-screen mixer: Easily extend the size of the mixer and more
• New look, same feel: Enjoy creating music more easily
• 960 PPQN MIDI resolution: Precise audio and MIDI event editing at the highest level
• 8 insert, 8 send effects: Create great-sounding tracks with flexible effects options
• FX rearrangement: Quickly rearrange plug-ins and change their pre/post fader position
• Pro-Grade effect presets: Make songs sound great with ready-to-use presets
• Undo with history list: Quickly jump back to earlier versions of your song
• Audio, MIDI and automation editors revisited: File editing is much more efficient
• Revised MediaBay: Your all-new control center for file and project management
• UI scale presets for smartphone and tablet: Quickly change the size and layout of Cubasis
• Overdub and looper recording modes: Choose the best mode for your recordings
• MicroSonic instruments refill: Be creative with great-sounding new instruments
• Improvements and maintenance: Enjoy the highest performance and rock-solid stability for your music production
Edit, mix, create. Cubasis 3 is the complete DAW app on your mobile device - make beats and songs like never before!
Technical support
http://www.steinberg.net/cubasisforum
If you like Cubasis, please support us by rating this app in the Google Play Store. Thank you!
*Cubasis for Android offers limited audio and MIDI hardware support only, Steinberg does not currently guarantee full compatibility.
nacho1000
How is the guitar connected to the phone?
Use a USB Class Compliant Audio interface + OTG Cable
The Nux MG-300 works well
Rhcole
Yeah, but Android stripped out the USB I/O versions 9 forward. You can't even get to them through Developers Options. It's like they disabled USB in.
Quote from: Rhcole on November 19, 2020, 01:45:27 PM
What is your Android device with non working USB OTG capability?
My Samsung Galaxy S10+ (Android 10) connects to this passive USB-C Hub
Just tested this week  - no need to enable "Developer option"
NUX MG-300 with the stock USB Cable connects via USB-A  to  this USB HUB
https://www.amazon.com/gp/product/B07Y1V18ZY/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
the above USB-C hub connects to the USB-C port on my Samsung Galaxy S10+ (Android 10)
and i can use Audio from MG-300 ( or any other USB Class Complaint Audio device) to record / playback 24 bit Stereo Audio into Cubasis , ExtremeAudio USB Recorder Pro, Field Recorder
My LG V20 on Android 9.0 works too
Rhcole
Admin,
I have three Samsung Android devices; a Note 8 that I refuse to update beyond 9.0 because that's how Samsung ruined my last phone, making it run hot, sluggish, with poor battery life. This phone stoppped processing USB recording when it changed from 8.X to 9.0
I have a Galaxy Tablet S4 that processed USB audio just fine until updated to 9.0. Then it no longer worked.
I have a Galaxy Tab S6 that came with 9X preinstalled, and it is on 10 now. It has never been able to record USB audio.
I love these tablets as Windows substitutes, but USB audio recording simply doesn't work on them, OTG be damned.
I do my recording on the iPad, because of these issues.
https://support.google.com/android/thread/20187567?hl=en
https://superpowered.com/android-usb-audio-android-midi
A quick Google search :
QuoteAOA protocol specifies how an accessory can establish communication with an Android device via USB. Due to the low power output of Android devices, AOA requires the accessory to act as a USB host, meaning the connecting accessory must power the bus.
Meaning a powered Hub may be required to power the USB port of the connected device and/or phone USB.
and:
QuoteAndroid devices can work in USB host or device mode. Host is the one which controls USB communication. PCs mostly operate in host mode. Device is the one which is being powered and controlled by the host. Flash drive is a common example of USB device. Linux/Android kernel supports device mode through different gadget drivers. UMS, MTP, ADB are different gadget modes on Android devices.
Later Android versions changed the options for USB, where you need to select in the USB menu, the type of mode the USB port operates in for a connected device.
Where previous versions required an OTG adapter to tell the USB port to operate in "Host Mode".
Rhcole
Tried powered mixers, cables, changed adapters, no dice. Hours wasted for nothing so far. Bright ideas more than welcome
Quote from: Rhcole on November 21, 2020, 01:37:02 PM
Maybe its your specific generation hardware
All my Android devices (LG V20, Galaxy S10+) employ USB-C  - which tends to have better OTG USB Hosting capabilities vs a micro USB device
(debug Galaxy S8 USB OTG)
https://us.community.samsung.com/t5/Galaxy-S8/S8-OTG-stop-working/td-p/807391
Even the Mooer GE300 works with my Android phones
just use this cable
https://www.amazon.com/CableCreation-Printer-Compatible-MacBook-Printers/dp/B012V563B6/
Here is Field Recorder app
https://lh3.googleusercontent.com/iNMirDA3jCHq5QWqGWUD8OW5zTu50H141lrP-7iqGVf6x7PaFFJIrYi7SPXXi0ABsA=w1920-h975-rw
https://www.vguitarforums.com/smf/index.php?topic=26308.0
Extreme Audio USB Recorder tested Hardware
http://www.extreamsd.com/index.php/technology/usb-audio-driver
Rhcole
Perhaps  just a liability of recent Samsung hardware or OS tweaks? Sure, why not?
At any rate, after a point it's time to let it go and come up with a workaround.
Would be nice and clean to use just one box.
Quote from: Rhcole on November 23, 2020, 04:15:29 AM
If you read the provided link above,  apparently an errant App might prevent  USB Audio on Galaxy S8
Id back up. and then do a factory reset. Remove all apps  -  then install USB Recorder or Field Recorder and test your USB Class Compliant Audio interface with a known working USB OTG adapter cable
https://play.google.com/store/apps/details?id=de.pfitzinger.rec&hl=en_US&gl=US
Google Play Store provides a 2 hour "test drive" or apply for a refund
