SY1000 version of Brent Flash Pedal Steel Patch
Started by 2pods, April 29, 2020, 04:07:52 PM
2pods
.......if it can be done.
Can different expression pedals be assigned to different note bends per string, different pedals to different intervals ?
What about kicking the harmonizer too ?
TIA
Fender G5 Strat, PRS SE Santana/w TriplePlay
jozart
I'm looking at the Assign Targets List starting on pg. 71.
Individual string pitch/fine can be targeted, as can depth, level, and pan (ooh!), but the pitch bend itself is a single target.
You could target separate instruments with separate pedals, where only a subset of strings are enabled in each instrument. That way one pedal could bend half the strings and another pedal bend the other half.
Also, several effects and instruments have two controllable pitches: pitch shifter, harmonizer, osc, etc. You could control each with a different pedal.
I suspect I'm not answering your question, but hopefully are pointing you in the right direction.
2pods
Every little helps.
I'm still thinking about it.
dnedwek
I think the 'Bend Depth' parameter in the Instrument 'Alt Tune' section is what you're looking for.
I tossed the attached patches (Boss live-set format) together to do some 5->1 bends.
2pods
Thanks, I'll give them a go
What with Covid etc, I haven't been using the SY1000 recently.
Spending too much time on forums  ;D
