Is it ok to plug a pedal (SY-1) out to GK in?
Started by DreamTheory, August 01, 2019, 04:18:51 AM
DreamTheory
I have plugged a guitar 1/4" into my GK in just to use the GR55's COSM and stomps. What if I ran my guitar into an SY-1 or other pedal and then into the GK guitar in? Could it damage the GR55?
SY-1 seems like a fun way to expand GR55's analog synth capabilities. Arpeggiator and more foot controls. But it lacks reverb delay and other things that would be available in GR55.
Also, SY1 has a side chain loop. Would it be better to run that to GR55?
mooncaine
You can put it into the Guitar In, if there is one, but you can't put it into the GK input. Only GK-compatible stuff can get plugged in there.
I assume you are referring to the guitar in on the GK-3 pickup,  inserting an SY-300 between the normal guitar jack and  the GK-3 normal guitsr in.?
Yes that will work fine.
mooncaine
Sounds like a brilliant idea, now that I understand what you mean. Or at least, what gumtown says; that makes me want to try something similar. Good idea.
DreamTheory
Yeah, I've done it with a bass or other guitar. I just wasn't sure if the output of a pedal had some sort of electrical charge that could fry the GK or GR.
This encourages me to try SY-1. Thanks Gummty!
ThomasDV
I've had similar thoughts... I found a variax with a gk-3 mounted on it on craigslist for dirt cheap 2 years ago and started testing it on my sy-1000. It really does open up a number of possibilities to have a secondary "Guitar model" available on the input. Since there is no variax kit to install on my other guitars and kits, I too have been thinking of picking up a gp-10 or gr-55 to use as a "variax" guitar modeler for a monstrous beast bass/guitar double neck that I am building. Used units are surprisingly low at the moment.
