GT1000 Core Tones - Leperclown
Started by Leperclown, May 25, 2019, 01:59:43 PM
Leperclown
Hi all,
attached is a file containing my 7 core GT-1000 patches (Clean, Grit, Crunch 1, Crunch 2, Crunch 3, Lead 1 & Lead 2).
Note:
- Created using a Les Paul with Seymour Duncan JB & Jazz pickups
- FRFR: Stereo Powered Denon DJ Axis 12's (amazing speakers!). EQ may need to be adjusted to suit various speaker brands
- In Lead 1 & 2, I use FX three as a momentary feedback generator (works ok)
Cheers!
Paul
roachone
Thanks Paul. I'll give these a go tomorrow!
PAH
Two things:
1) A couple notes to people who try these: a) these are setup for the Sub Outs.  If you're using the main outs, you need to copy the speaker settings over on each patch.  Also, the volume pedal is
setup to only run from 70-100, so if you amp is up loud, rolling back on the pedal won't get it all the quiet - my parrot loved it.
2) These sound frickin' awesome.  THANKS!!!!  Now, I'm inspired to play around with parallel amps and cabs.
