HX Stomp with Bluguitar AMP1 & Remote1
Started by Stezzer99, November 07, 2018, 03:59:22 AM
Stezzer99
Hi
Hope someone can help!
1) I'll be wanting to use a 4cm with this but also have some scenarios where id like to use one of the helix preamps/amps straight into the effects return of the Amp1.
Will I be able to set up patches for both the above scenarios without having to remove cables (ie remove cable from HXS to the Amp1 input)
2) Ill be using the Bluguitar Remote1 footswitch which i believe doesn't send CC messages, only PC! Is it possible to change Snapshots using PC messages?
Sorry if this sounds dumb but this midi stuff is v new to me!
Regards
Steve
