How should I run my SY-300 with my Helix and FRFR?
Started by Rocco Crocco, August 31, 2018, 02:53:24 PM
Rocco Crocco
I am using the SY300 into the FX loop of the Helix. Do you guys that have a Helix or similar device use an amp block or speaker block in the signal chain of the modeller, or if its best to just run the Boss unit into an empty Helix preset and stright to FoH (while adding desired EQ, ect if needed).
arkieboy
I run my VG99 into a separate input path on my Helix, sharing the final reverb block to glue the sounds together.
See https://www.vguitarforums.com/smf/index.php?topic=23099.0
Guitar > SY-300 input
SY-300 guitar thru > Helix input
Helix L/R output > SY-300 Return L/R
Set the SY-300 global Return level to match the SY-300/Helix levels.
Rocco Crocco
Quote from: arkieboy on September 01, 2018, 02:03:01 AM
Do you have an amp and/or speaker block on the same path as the synth to goose the signal?
Rocco Crocco
Quote from: gumtown on September 01, 2018, 02:30:08 AM
Do you have an amp and/or speaker block on the same path as the synth to goose the signal? There is no multiquote feature so I had to ask you both separately.
There's only mono return on SY-300
Quote from: Brak(E)man on September 01, 2018, 04:52:25 AM
yes.. I forgot..
what about SY-300 L/R out into Helix Return (1/2 or 3/4) after the amp sim.
Synthetica
I hadn't used my SY-300 for a while and just recently got a Helix and a Powercab Plus. I decided to hook up the SY-300 to the Helix and Holy mother of sound !!!.  I have the Guitar into the Helix. Helix FX1 Send going into SY-300, Sy-300 out to FX1 return. Helix L6 Link out to Powercab Plus. Helix XLR outs to a mixer with JBL active monitors. I tried the with the ISS Flyby Preset on the Helix.
Add a FX1 block and drop it down to a new path in the Helix. Set the output of that Path to go to the Helix XLR outs (this sound goes to the mixer and the monitors)  Set the Output of the regular 2A path to go to the Digital out which sends the regular guitar path to the Powercab. Added a Volume Gain block  on the SY-300 Path in front of the FX1. Set the SY-300 to the Phased Strings preset. Added a Parametric EQ block after the FX1 block to tame the SY-300 with a bit of  Hi-cut. Strum a guitar chord and it sounds like I'm playing an orchestra. I'm gonna have fun with this.
BROCKSTAR
Quote from: Synthetica on January 20, 2019, 09:07:32 AM
Thank you so much for this. I got a sy-300 coming in few days and I have a helix floor as well I wanna use with it and was wondering how to hook it up the best.
arkieboy
Quote from: Rocco Crocco on September 01, 2018, 02:58:11 AM
No.  In this configuration I only use my VG for acoustic guitars and synths. Aim is a pristine signal path.
