KV331 Audio- SynthMaster One 4+ Powerful wavetable synth
Started by Elantric, June 22, 2018, 02:13:38 PM
SynthMaster One 4+
KV331 Audio
4.1, 23 Ratings
$14.99
iPad Screenshots
  https://itunes.apple.com/us/app/synthmaster-one/id1254353266?mt=8
  https://www.kv331audio.com/
Description
SynthMaster One iOS is the mobile version of KV331 Audio's SynthMaster One software synthesizer, which was recently voted "The Best New Synth of 2017" by MusicRadar readers.
SynthMaster One iOS is feature wise identical to the desktop version except the following:
* 16 voice polyphony (32 for the desktop version)
* Comes with 500 presets (800 for the desktop version)
SynthMaster One iOS is KV331 Audio's first full blown synth app for the iPad. It's a powerful wavetable synth with an intuitive workflow. With its simple layout, rich wavetable/waveform content and inspiring factory presets library, designing new sounds with SynthMaster One iOS is a joy.
FEATURES
* 500 Factory Presets: SynthMaster One iOS comes with inspiring factory presets from a world class team of sound designers: Arksun, Aiyn Zahev, BigTone Studios, Bluffmunkey, Bulent Biyikoglu, Gercek Dorman, Dejavu Sound, Nori Ubukata, Rob Lee, Ufuk Kevser, Selcuk Ergen, The Machine, Vandalism Sound, Vorpalsound and Xenos Soundworks
* AUv3: SynthMaster One iOS supports AudioUnits V3, allowing multiple instances to run under supporting DAW apps like GarageBand, Cubasis or Beat Maker. It also supports parameter automation and full screen when running inside GarageBand.
* AirDrop: Easily share your presets over AirDrop, Mail or other iOS Applications. SynthMaster One iOS presets are interchangeable with the desktop version.
* Semi-Modular Architecture: For each SynthMaster One instance, there are 2 oscillators with 2 sub oscillators, 2 Filters, 4 ADSR Envelopes, 3 LFOs, a powerful 16 step arpeggiator/sequencer and also 11 different effects that can be inserted on to 6 FX insert slots. The sub oscillators can be connected to the oscillators in 5 different modes which let you use it as a regular sub oscillator or do complex modulations such as ring modulation, amplitude modulation, phase modulation or frequency modulation.
* 16 Step Arpeggiator/Sequencer: The arpeggiator in SynthMaster One features classic arpeggiator modes such as Up, Down, UpDown, DownUp, UpDown2, DownUp2, AsPlayed as well as Sequence, Chord and Arpeggiate modes. Each of the 16 steps of the arpeggiator has its own Velocity, Note Number, Note Length, Slide and Hold parameters.
* Wavetable Synthesis: SynthMaster One implements true wavetable synthesis which opens up new possibilities for sound design. SynthMaster One comes with a rich wavetable library and you can extend that by dragging and dropping wavetable files using the Files App (requires iOS 11+)
* Stereo Oscillators with up to 16 voices Unison: Each of the 2 oscillators in SynthMaster One have stereo output, and can have up to 16 voices "unison". Using the "voices", "voices mix", "detune curve", "detune spread", "pan stread", "tone spread" and "phase spread" parameters, each oscillator can generate a rich "supersaw" type sound.
* Zero Delay Feedback Filters: All of the 4 filter categories in SynthMaster One are developed using the zero delay feedback filter technology. With advanced filter parameters like input gain, drive, acid, filter nonlinearities and up to 4 times oversampling you can get that "analog" sound from the filters!
* Rich Set of Effects: SynthMaster One features 11 different effect types: Distortion, LoFi, Ensemble, Phaser, 6 Band EQ, Compressor, Vocoder, Delay, Chorus, Tremolo, Reverb.
* Microtuning: SynthMaster One supports Scala tuning, so tuning can be set either for each preset or globally by loading from a Scala tuning file.
* Preset Browser: SynthMaster One features a comprehensive preset browser with separate search criterias for instrument type, preset attributes, music style or preset author.
SUPPORTS
* All 64-bit iPad devices
* AUv3 Audio Unit Extensions
* Note-per-channel MIDI controllers (MPE)
* Ableton Link
* Interapp Audio and AudioBus
* Bluetooth LE MIDI Controllers
* Share presets over AirDrop, Mail or other iOS applications
thebrushwithin
