Katana - MIDI SYSEX ( Tap Tempo)
Started by spankygtr, April 19, 2018, 05:38:45 PM
spankygtr
Trying to find out if theres a way to send tap tempo to my Katana head from my MS-3, hopefully globally
Sadly there is no published Katana MIDI specification
( But I suspect Katana does NOT support external MIDI Tap Tempo control , unless you use SYSEX  - or  PrimovaSound MIDX-20
http://www.primovasound.com/midx_20.html
Katana MIDI Implementation was reverse engineered by a few gurus here
https://www.vguitarforums.com/smf/index.php?topic=20693.0
https://github.com/snhirsch/katana-midi-bridge/blob/master/doc/katana_sysex.txt
Quote[Parameters]
Note: Tap Tempo equivalent to setting delay time, but it
      averages time between button presses.
Delay Time (1,..,2000ms)
60 00 05 62 --> 00 01 .. 0F 50
Note1: hhll is an 11-bit value representing ms intervals between taps
       (Max 2000). Because sysex data is limited to 7 bits, encoding
       is:
       hh                            ll
       0 0 0 0 b10 b9 b8 b7    0 b6 b5 b4 b3 b2 b1 b0
       So, the maximum value would be 0F 50, or
       0 0 0 0 1 1 1 1     0 1 0 1 0 0 0 0
https://www.vguitarforums.com/smf/index.php?topic=19707.0
and the current known Katana MIDI implementation is here
https://github.com/katana-dev/docs
BTS_katana_sysex.txt (202.3 kB )
https://www.vguitarforums.com/smf/index.php?action=dlattach;topic=19707.0;attach=15492
Quote{
      "name": "sw_tap",
      "address": "7F,01,01,03",
      "size": "00,00,00,01"
FWIW - its best to open above file with share ware "smart" text editor
NotePad++
https://notepad-plus-plus.org/
C:\Program Files (x86)\BOSS TONE STUDIO for KATANA\_assets\data\addressmap_gt.json (1 hit)
   Line 1589:       "name": "MIDI SETTING: SYNC CLOCK",
