ammoon Stereo Looper Pedal:
Started by admin, February 02, 2018, 04:31:18 PM
USA:
https://www.amazon.com/dp/B074BNDD19
ammoon Looper Pedal:
Specifications:
Brand: ammoon
Max. Loops: 10 independent loops
Each Loop's recording Time: max. 10 minutes
Sampling Frequency: 44.1KHz/ 24bit
Input Jacks: 2 * 1/4" TRS jacks(L & R), 1 * 1/4" TRS Jack(for external foot controller)
Output Jacks: 2 * 1/4" TRS jacks(L & R)
Power Supply: DC 9V 140mA (center minus)
Fade Out Time: 0(stop immediately), 1(1s), 2(2s), 3(3s), 4(5s), 5(10s), 6(15s), 7(20s), 8(25s), 9(30s)
Compact and powerful stereo looping pedal, high quality uncompressed audio: 24-bit A/D/A, 44.1KHz sample rate and unlimited overdubbing.
10 selectable, independent loops, and each loop's recording time is up to 10 minutes.
True stereo connections allow looping of 2 separate instruments simultaneously.
Reverse, 1/2 speed, undo/redo and fadeout effects all easily controlled via the dual footswitches.
A 3rd footswitch can be added via the ext input for even more hands free control.
Perfect for practice and live performance.
LOOP footswitch for activating RECORD, DUB(record and add an extra layer to you loop) and PLAYBACK operations;
STOP/FX footswitch for stop, clear and FX functions;
REVERSE--playback your loop in reverse;
1/2 SPEED--playback your loop at half the speed it was recorded.
https://www.amazon.com/ammoon-Independent-Recording-Unlimited-Overdubbing/dp/B074BNDD19/
