SOLVED: FTP Block new notes working with IK Blueboard on iTrack dock
Started by Smash, October 03, 2017, 08:38:47 AM
Smash
Sending CC66 from the blueboard will not trigger the block new notes feature of FTP in hardware mode on its own when you're using it with an iTrack dock - you simply get regular sustain feature and new notes will trigger.
The solution I've found is to run MIDIflow (it's an indispensable app for any midi use in iOS imho).
Set up a new channel strip in MIDIflow and set its input to Blueboard then simply set its output to iTrack. This routes cc66 to the FTP and voila, the block new notes function now works. I use one of the expression pedals on Blueboard in CC mode to control CC66.
Hope this is helpful
