MIDX-20 MIDI/SYSEX Implementation
Started by CodeSmart, September 09, 2016, 02:24:36 PM
CodeSmart
This small document cover the most vital SysEx MIDX-20 commands to control the MIDX-20 using 5-PIN MIDI IN/OUT connectors. This allow for third party developers program the MIDX-20 from any operating system or device.
http://www.primovasound.com/pdf/MIDX20_MIDI_Implementation.pdf
The SysEx commands can be used to configure the EPPROM allowing up to 24 arbitrary MIDI bytes to be fired off when one of the four possible CTRL1/CTRL2 footswitches is pressed or released. The interface also allow footswitch logic inversion and auto-repeat function for PC+/PC-, options disabled by the limited one-button built-in Setup Wizard.
If the document is unclear please send the question to sound@primova.se and I'll expand the manual.
This described programming interface will be used by the upcoming MIDX-20 Assistant Windows PC program.
