GR-33 - Connecting to PC
Started by MaxWanted, April 08, 2016, 03:51:15 AM
MaxWanted
Hello guys.  How to connect roland gr-33 to my PC?
GR-33 has no USB connector, only  midi  in / midi out.
I have  midi-usb cable  http://ecx.images-amazon.com/images/I/31l6n6mRLyL._SY300_.jpg    and godin SA + 13pin cable ofc
I want to operate the VST(for exp. cubase) with the help roland gr-33. Help me pls.
Sry for my bad english  ::)
The worst possible midi device adapter you could get is this
They are not up to data stream transfers like system exclusive patch data, and most have the required optical isolation missing.
I recommend a Roland UM-One midi device adapter, it will always work....
You can use that to drive VST midi instruments via the GR-33 midi port.
MaxWanted
Quote from: gumtown on April 08, 2016, 05:15:16 AM
Ok, thank you. I try it.
If you own GR-33 - and want to record, you also need an Audio Interface for your WinPC or Mac, and many include 5 pin DIN MIDI I/O.
If you are on a budget, I always recommend owning an Audio Interface that not only has decent Mic Pres, and good audio specs, 24bits@ 96kHz minimum, but also has 5 pin DIN MIDI I/O jacks.
Review the Survey of Audio interfaces,
https://www.vguitarforums.com/smf/index.php?topic=8291.0
the Focusrite Scarlet 2i4, Roland Duo-Capture EX  Duo are affordable and meet these requirements.
many more here
https://www.vguitarforums.com/smf/index.php?board=193.0
MaxWanted
Quote from: admsustainiac on April 08, 2016, 06:16:40 AM
many more here
Thanks! (I have Roland UM-One now  ::) )
I understood. Have some money and i will buy one of audio interface
FOCUSRITE Scarlett 2i4 gen
TASCAM US-2x2
STEINBERG UR22 MKII.
Another question  ???
many 5 pin DIN MIDI I/O jacks ?
GR-33 [midi in] ----> Audioface [jack 6.3 in]
GR-33 [midi out] ----> Audioface [jack 6.3 out]
https://images-na.ssl-images-amazon.com/images/I/51MLzlKEr4L._SL1000_.jpg
or
GR-33 [midi in] ----> Audioface [midi in]
GR-33 [midi out] ----> Audioface [midi out]
http://i.ebayimg.com/00/s/NDI4WDg1Ng==/z/M-4AAOxyUylTUD4B/$_57.JPGttp://i.ebayimg.com/00/s/NDAyWDUwMA==/z/egsAAOxyOlhS-oN3/$_103.JPG?set_id=2
Scarlett are great
Midi out to midi in
vtgearhead
I've had great luck with an M-Audio MidiSport 1x1.  Handles large sysex messages with no problems at all.
IGMartin
I've used the Midiman USB Midisport 2 x 2 with great success.
