PRIMOVA - GKPX-14 a smarter GKP-4 clone/4 channel GK distribution box
Started by CodeSmart, August 06, 2014, 10:50:52 AM
szilard
Quote from: CodeSmart on March 27, 2020, 11:03:41 PM
My supplier doing milling and printing has finally been able to print a new batch of GKPX-14 enclosures.
This means I can now start to assemble new units. It's been a long wait.
Glad to hear that. Given that we're in the midst of a global pandemic I'm not surprised there are some delays ...
CodeSmart
Quote from: szilard on March 28, 2020, 10:05:03 AM
Actually mostly it was related to a industrial flatbed printer size of a small room, printing on wood, glass, metal or almost any material, that had gone bad in the printing head.
Had to wait a month for the service engineer replacing the head for abt. $3000. It's a really cool machine. Also prints white color.
Hurricane
;D
Have you a 90° Angle hex that allows both 1/4 inch inputs to be accessible at the same time.
I asked before a long time back.
CodeSmart
Quote from: Hurricane on July 06, 2020, 05:09:43 PM
;D
Really can't figure out what you're asking for Hurricane Amigo. Please explain better (I mostly speak Swedish you know)  ;D
thebrushwithin
Sounds like he may have a Godin where there is the 13 pin connector in between a 1/4" jack for magnetic, and also a 1/4" jack for piezo. If so, most right angle 13 pin connectors block the piezo output, when inserted. So, if the 13 pin connector could right angle downward, it would alleviate the problem. I know I would also like that for my Godins.
CodeSmart
Quote from: thebrushwithin on July 07, 2020, 10:06:58 AM
On request I can turn the angle in any 45 deg steps. Often need to re-solder one 'magic' ground wire but that's ok. You may have any of the four quadrants if asked for. Cheers.
Hurricane
That's cool and thank you thebrushwithin for assisting.
Yes to being able to have that 90° angel so I can have access to both inputs of the guitar with the 90° plug .
On stage the my guitar's straight plug cable hits the floor on many of my guitar stands.
A 90° angel plug helps prevent this.
Please realize I haven't been on line a while while in Mexico.
°¿°What is the cost for a cable with this 90° facing away from the guitar °?°
Thank you. And where in Sweden are you I have relatives  there.
EZ :
Hurricane
CodeSmart
Quote from: Hurricane on July 07, 2020, 04:40:14 PM
EZ :
Hurricane
24USD for 3 meter, 30USD for 5 meter. Straight-Angled. Shipping 7-15USD depending on country.
Email sound@primova.se
I'm little East of Karlstad.
CodeSmart
Started production of another 50 pcs GKPX-14 units. It's been a while since the last batch.
- Enclosures - Done!
- New PCB's - Going into production as soon I get the go from producer. Everything handed over.
/Robert
Fratzebill
I LOVE TO BUY ONE TO GET AWAY FROM MY SPIDER NETWORK (5x Y Cables)
Old Man
Ready for Knockin' on Heaven's Door
CodeSmart
The GKPX-14 and GKPX-14F is now ready for sale again.
I've got 50 pcs brand new boards and they work fine.
(the F-version has a Subsonic Filter for taming Piezo Guitars)
GKPX-14 GK synth switcher $170USD (1 in, 4 out)
https://primovasound.com/products/gkpx14/index.php
Also remind you I've got the Primova GX-2 out for only $320 this Black Week.
GX-2 GK guitar and synth pre-amp and switcher $320 (2 in, 2 out)
https://primovasound.com/products/gx2/index.php
Fratzebill
Hi,
is anybody thinking about to use a raspberry for stomping the Patches ?
i know my GR33 allways boot with the same Patch i will find out if other devices
can be programed the same. than the GKPX know how to start and you can select the Patches via a GUI for all
an send it to the GKPX
(sorry my english is not the best)
Old Man
CodeSmart
Quote from: Fratzebill on November 24, 2022, 02:44:03 AMHi,
Hi I'm not sure how you think that would work. GKPX can't send patch change not even pull S1/S2 buttons. It's simply a 2xUS-20
Fratzebill
#138
hi,
ok
The Reason i was thinking about this was i am currently using Y cables.
if i connect all my Devices sometime one device starts changing patches .
and this was not allways the same device.
i got everthing install in a Rack except the VG-99
with a US-20 before the Y-Cables
my idea was if i can select the device (stomping) i can send signals to the 13 pin to change patches
10 Down switch signal (switch to GND)
11 Up switch signal (switch to GND)
let the raspberry know what patch is active for each device
so can create playlists to change patches on all Device via the raspberry
something like this
VG-88  GR33  GR55 SY-1000
03-3  C31  05-3  02-2    Set1
01-1  D32  14-2  10-1    set2
Regards
Old Man
CodeSmart
Ok, if I follow you're thinking you want to use three Arduino ports.
Port 1 : Emulate S1 pressing
Port 2 : Emulate S2 pressing
Port 3 : Emulate GKPX footswitch pressing
1. You run port 3 with a specific pattern to pass S1/S2 only to GKA
2. Operate port 1 & 2 for S1/S2 intil done with GKA
3. You run port 3 with a specific pattern to pass S1/S2 only to GKB
4. Operate port 1 & 2 for S1/S2 intil done with GKB
5. You run port 3 with a specific pattern to pass S1/S2 only to GKC
6. Operate port 1 & 2 for S1/S2 intil done with GKC
7. You run port 3 with a specific pattern to pass S1/S2 only to GKD
8. Operate port 1 & 2 for S1/S2 intil done with GKD
If this is your thinking it would work but each total song change would require some seconds due to foot switch timing.
Personally I would control the synths using Arduino with MIDI out, having all synths listening for PC# on different MIDI channel.
VGA-7
Santa has arrived early in Hawaii!
Mahalo nui loa!  You have made my dreams come true. With the addition of your GXPX-14 I now have united my family. VGA-7,GR-33,GP10,SY1000. And
 connected with your superior GK cables they have never sounded as good. I want to wish you and all the VG community a Mele Kalikimaka.
Gibson L6S /gk2a , Bradley mini strat  /gk2a VGA-7 amp ,GR-33 , GP-10,SY1K, RMC breakout box, PK5 midi pedals,CM-64 sound module, Oberheim EDP  ,Boss RC-300,Digitech TRIO and TRIO +, Alesis DM5, GX2 Gear Shifter and GKPX-14
CodeSmart
Quote from: VGA-7 on December 07, 2022, 12:02:58 PMSanta has arrived early in Hawaii!
Aloha VGA-7,
Mele Kalikimaka and many thanks back to you. However I'll be on Canary Islands during X-mas (if me and war department recover from the flu in time).
Feliz Navidad amigo! (started working on the Spanish ;) already an expert on using "Una cerveza por favor" )
Mahalo
Robert
Fratzebill
Old Man
CodeSmart
A tip:
In case you are going to use the GKPX-14 with two synth units, this is my favorite setup.
When you:
-    Click once it will toggle between GKA and GKB
-    Double-click, both A & B will sound.
-    Double-click again, only one will sound.
(When in mode with both sounding, single click will route S1/S2 to the one that is orange).
To do this:
1.    Hold down the footswitch/button > 7 sec (all leds start to blink green)
2.    Double-click button (all leds starts to blick orange = US-20 mode)
3.    Click patiently two times (only two leds blick orange = 2 inputs)
4.    Double-click button (one led flash green = Stomp pattern 1)
5.    Click once (two leds blick green = Stomp pattern 2)
6.    Click once (three leds blick green = Stomp pattern 3)
7.    Double-click button (end programming)
In case you want to set it back to factory settings:
1.    Hold down the button > 7 sec
2.    Single-Click until all flashes green
3.    Double-click
4.    Single-Click until all 4 flashes orange
5.    Double-click
6.    Single-Click until only 1'st led flashes green
7.    Double-click
