BR-80 - eband song list editor....
Started by stevef1, February 24, 2013, 09:55:31 AM
stevef1
Hi all, having some problems with eband song list editor, it jus wont connect to my device GRRRRrrr
any ideas on an easy way to get songs on to the br 80 without using the software?
thanks
stevef
Did you install the BR-80 USB driver software?
Without it the eBand editor (or anything else) won't see the BR-80.
The Eband song data is in a proprietry format, so you need it  to install songs.
I have used a card reader with the BR-80's SD card ( or it may have been another Boss device?) to bypass the USB connection.
stevef1
Hi and thanks, all drivers installed ok, USB lead works ok, I can see the ad card mount under windows when the br80 is connected, the br80 works using cakewalk etc. it's just the beans software !!!!
Will try the so card in the computer and see if that works
stevef1
WTF !!!!
Just tried a different ad card, think it was the first one I got for it.
E band works now.... Weird
Thanks will try and find out now why the ad card can be seen by the software when the other one can...
Do you have the latest BR-80 firmware installed?
The latter firmware reads more SD cards, the earlier versions were fussy on SD card brands.
