GK-3 issue
Started by beatpete, December 01, 2022, 02:59:44 PM
beatpete
I hope someone can help me. I have 2 guitars, one with a GK-2a that works fine a another with a GK-3 in which the top 2 strings (mostly the E) are considerably lower in volume. When i go to my GK setup in my SY-1000, all strings show fairly equal levels but in a patch I have to have the E to 100, the B to 75 and the others around 15. Any ideas what this could be?
I've cleaned both ends with cleaner and plugged/unplugged several times.
beatpete
Quote from: Bluesbird on December 01, 2022, 03:19:48 PMMeasure the string to pickup distance. Is it 1 mm? How close is you GK pickup to the bridge? What kind of bridge? Tuneomatic? Show a picture if you can. That difference of 15 and 75 to 100 seems excessive. Bad pickup? Can you swap pickups to see if the GK2a works on this guitar?  Even if it is not the cable,  I strongly recommend the PRIMOVA SOUND cables for their reliability:
https://primovasound.com/products/cables/index.php
Thanks for the reply. The string to pickup distance is around 30mm (the max) and the bridge is a floyd rose (same as on the other guitar).This used to work but I haven't used my GK system for a while so I suspect there's a problem with the pickup
stub
That doesn't explain why the levels look right in the setup, but change when you go out into the instruments. Have you tried jacking up values in the setup to compensate?
You would think that is the GK senseitivity VU metrs show equal string levels, that the instruments would also produce equal levels on each string.
Patch backup and Factory reset fix it?
