GI-20 and current IOS (10.15 and above)
Started by Mojorisin, December 01, 2021, 02:40:12 AM
Mojorisin
Hi all,
I' d like to know if you still work with a GI-20 Midi Interface and if your happy with it.
What DAW do you use?
Thanks to you.
Mojo
vero70
Hi, GI-20 is USB class compliant - works fine in MAC OS and in IOS, in Logic as in other daw or midi related software (virtual synth etc.)
You may only set the driver mode in GENERIC mode. To do this, follow this steps:
1. Turn off the power to the GI-20.
2. Hold down [WRITE] and turn on.
3. Press [SELECT] until only the leftmost indicator of the display is light up (at this point you can select USB DRIVER TYPE)
4. Press [PATCH/VALUE] to select  "GE"
5. Turn the power off.
6. Turn the power ON
Now you can see the GI-20 in studio midi window on MIDI AUDIO CONFIGURATION utility and in all the software that use external midi input.
