Best Expression Pedal to use with SY-1000
Started by ILIADE, October 14, 2021, 01:29:03 PM
ILIADE
Hi guys -- I am about to buy a SY-1000 and was wondering what was your recommendation for an expression pedal. I used to have a GP-10 and was mainly using the pedal as a volume pedal but now I need to get an external one. Any recommendations?
Thanks,
Chris
Roland EV-5 ( easy to carry  lightweight, but durable)
Roland EV-30 -a bit more durable, has dual control TRS out jacks, can pan between 2 Boss Processors
Kevin M
I use a Boss FV500H. It's a nice heavy duty pedal.
ILIADE
Thank you guys for the quick response. For the FV-500, why choosing the H version instead of the L?
Chris
arkieboy
IIRC both FC500s have a separate expression output that is the same.
The H is mono, and is high impedance for working with guitar-level signals.
The L is stereo and is suited for working with keyboard-level signals.
I guess it depends on what else you might want to use the pedal for as to which you buy.
Steve
Kevin M
Quote from: arkieboy on October 15, 2021, 07:41:22 AM
Steve
Yes, exactly. I think, technically either version will work with the SY1000, though.
jozart
#6
I use a FV-50L with TRS cable for EXP2.
I use EV-30 for EXP1.
I also plan to use the EV-1-WL with BLE MIDI when it ships. I have a BLE MIDI adapter attached to the 5-pin DIN MIDI connections.
Harry1227
#7
Hello. I use a Chinese pedal Sonicake. I've improved its functionality by installing the button. So I use it as an expression pedal with a switch (Exp1 and ctl 3 or 4)
ILIADE
Thanks everyone, I think I'll go with the EV30. Another quick question while I'm waiting after my SY-1000 to be delivered... I also have a GP-100 and was wandering if I should keep it or not. Assuming I keep it (as far as I know, the SY-1000 don't have a looper), how would you connect the 2? I use a GK3 pickup with my Les Paul.
Thanks again, your suggestions and inputs are very helpful!
Chris
GT-100 ?
I would place it in the SY-1000 Send/return loop.
The loop can be moved around the SY signal chain, so you can loop at any section of the SY.
ILIADE
Love this forum! Is there a way to use the expression pedal of my GT-100 with the SY-1000? Might be a stupid question but I have to ask 😉
Kevin M
Quote from: christiandubuc on October 16, 2021, 09:54:04 AM
Yes, there is. The GT-100 can send expression pedal information vie MIDI CC messages. Check both products' respective manuals for details.
drjoness2001
#12
I uploaded a YouTube video with a comparison of various pedal used with the SY-1000:
https://www.joness.com/gr300/sy-1000-expression-pedal-roland-ev-5_boss-ev-30_moog-ep-3_mission-engineering-sp-1.html
Roland EV-5
Boss EV-30
Moog EP-3
Mission Engineering SP-1
ILIADE
So you mean from SY-1000 SEND to GT-100 RETURN and from GT-100 SEND to SY-1000 RETURN?
Or from SY-1000 SEND to GT-100 INPUT and from GT-100 OUTPUT to SY-1000 RETURN?
Thanks for your help.
Chris
Quote from: gumtown on October 15, 2021, 02:49:04 PM
GT-100 ?
DeRigueur
You probably want to go from the SY send to the Gt100 input and the Gt100 output to the SY return.
You may need to adjust levels between the 2 units.
Quote from: DeRigueur on April 03, 2022, 06:51:58 PM
This !!
