Revamped my GK-3 strat
Started by Zummooz-fgn, March 24, 2012, 10:28:21 PM
Zummooz-fgn
I changed my bridge ...
These shown here are a replacement part for a 6 hole Vintage Tremolo.
Got a couple of these replacement Aluminium Bridges to try out.  ;)
These are proto types I have here, 1st in oz, that I've put onto my 'Redback' Red Quilt Strat GK-3
Can get them as Anodised, these ones I have are Polished Aluminium.
Weight of Original 6 Hole Vintage Trem + Block with Original Saddles ..... 325 grams
(Not including 6 mounting screws)
Weight of this 6 Hole Replacement Bridge + Block with Graph Tech Saddles ...... 317 grams
You still have the trem block attached and springs for earthing ..... This is a replacement part !!  ::)
I haven't put a piece of wood between the Block and the Trem cavity wall, But will be doing that.
The way I have it now.
Works great, easy to fit ...  ;D
I just added some Graph Tech Saddles and away we went !!
Very comfy now and the GK-3 pup sits, where it originally was nicely in front of it.
Kind of out of the way .... as to speak.
Even if the GK-3 pup was turned around the other way, would be out of the way with this new bridge.
These are made as a replacement for 6 hole vintage tremolos.
BUT ....
They come in other styles as well .... Strat flat mount, Tele flat mount etc for different string spacing.
If using with a pickguard, need to cut some out.
But these will be available sometime as well.
I think it looks good on this one.
Cheers Zum  ;D
BEFORE
BRIDGE
TREMOLO OUT
NEW BRIDGE IN
AFTER
gumbo-fgn
Good One, Zum!!!
Well done!     ;D
Elantric-fgn
Interesting Aluminum bridge - but I'd miss the use of my tremolo arm.
aliensporebomb-fgn
Very nice.  But I have to ask: where do you get the custom neckplate?  That's great!  I want to make one for my custom "orange crush".
Zummooz-fgn
Quote from:  aliensporebomb on April 01, 2012, 06:04:32 PM
Thanks  ;D
Made from a guy in Texas from the Warmoth forum. $40 each
Here's a link to his (rather long) custom plate thread ...  http://www.unofficialwarmoth.com/index.php?topic=34007.0
Can PM him (DangerousR6) from that forum, and I usually send him description and some pic's or drawings of what I'd like.
Or something I found around the web !!
He is great to work with, meaning good correspondence between him & you.
Dose some other stuff too, Truss covers etc.
Here's a few he's done for me.
