Room EQ Wizard
Started by Elantric-fgn, August 18, 2010, 06:49:34 PM
Elantric-fgn
http://www.hometheatershack.com/roomeq/
Room EQ Wizard is a Java application for measuring room responses and correcting modal resonances. It includes tools for generating test signals; measuring SPL; measuring frequency and impulse responses; generating spectral decay plots, waterfalls and energy-time curves; generating real time analyzer (RTA) plots; calculating reverberation times; displaying equaliser responses and automatically adjusting the settings of parametric equalisers to counter the effects of room modes.
Key Features
    * Free!
    * Support for the Behringer Feedback Destroyer Pro models DSP1124P and FBQ2496, including filter setup via Midi (Midi interface required). For a great resource on using the DSP1124P with a sub, check out the BFD Guide.
    * Support for the TMREQ equaliser in the TAG McLaren AV32R DP and AV192R AV processors, including filter setup via RS232
    * Signal Generator offers sine waves, square waves, linear and logarithmic sine sweeps, random pink noise (full range, speaker calibration, sub calibration and custom filtered) and periodic pink and white noise
    * Compensation for C-weighting when using an external SPL meter as the input, calibration files can be loaded for microphones or SPL meters
    * Existing measurement results can be imported from ETF 5, text files or WAV files
    * Frequency response measured using logarithmically swept sine signals for fast, accurate measurements with approx 0.36Hz resolution across the measured range or via real time analyzer with up to 1/48th octave resolution.
    * Impulse response is derived from the measurement, allowing spectral decay plots, waterfalls and energy-time curves to be generated. Impulse responses can be exported to and imported from WAV files with 16, 24 or 32-bit resolution.
    * Reverberation times derived in accordance with ISO 3382 in octave or one-third octave bands with results for Early Decay time (EDT), T20, T30 and an optimal fit RT60 figure.
    * Automatic identification of peaks in the response, automatic assignment of filters to peaks and optimisation of filter parameters to counter the peaks
    * Filter settings and sets of measured data can be saved to and restored from files. The filters' impulse response can be exported as a WAV file for use with a convolver plug-in, such as http://convolver.sourceforge.net/
    * Comprehensive help files within the application and on-line
bosetuno
I think this is the link for roomeq now
AV Nirvana REW download
https://www.avnirvana.com/resources/
diecairo
