GR-20
Started by DW, May 26, 2010, 07:07:49 AM
Melvin C
Does the GR-20 allow another midi device (computer?) to be driven with different sounds simultaneously?  ie...  synth sounds from the GR-20 and horns from my computer midi banks?  Just wondering if there is a midi out from the GR that is just the guitar midi info?
Thanks.
DW
simont-fgn
Elantric-fgn
See the GR-20 manual
http://lib.roland.co.jp/support/en/manuals/res/1811579/GR-20_e6.pdf
page 28
MIDI Mono mode
Performance data for each string will be transmitted individually,
with each using its own separate MIDI channel. Starting with the
selected MIDI CH, six consecutive MIDI channels will be selected
automatically. For example, if MIDI CH is set to 3, the six channels
3–8 will transmit MIDI data for strings 1–6, respectively.
Since continuous pitch change data (MIDI Pitch Bend messages)
can be transmitted independently for each string, this allows you
to use performance techniques typical of a guitar, such as use of
the whammy bar and string bending.
* The connected sound module must be a multitimbral sound
module with at least six parts.
