Ampero Control
Started by admin, September 06, 2021, 01:25:14 PM
https://www.hotoneaudio.com/products/controlers/Ampero%20Control
APPLICATION SCENERIOS
Using Ampero Control to control other devices via MIDI OUT/THRU jack
Notes:1. Arrows indicate MIDI signal flflow; solid line stands for MIDI messages coming from Ampero Control, dashed line stands forMIDI messages transferred by Ampero Control.2. Ampero Control cannot be controlled by other MIDI devices at present.
Using Ampero Control's MIDI IN jack
Using Ampero Control's USB MIDI function
Using Ampero Control's Bluetooth MIDI function
Notes:1. Ampero Control can only be paired with one device at a time.2. Ampero Control does not support receiving/transferring Bluetooth MIDI messages.
Features
✪ Compact, smart 4-footswitch Bluetooth MIDI controller
✪ Supports standard MIDI, USB MIDI and Bluetooth MIDI input/output/thru
✪ Sending/transferring MIDI messages to separated/combined MIDI outputs
✪ Send max. 16 MIDI messages by one footswitch (32 for A/B groups)
✪ 100 banks (each bank includes 4 footswitches settings, 2 CTRL/EXP jack settings and more)
✪ Different footswitch triggering actions for flexible switching and various uses
✪ Dedicated mobile App lets you easily set your controller on the fly
✪ 2 CTRL/EXP TRS jacks for adapting external footswitches/expression pedals
✪ 3-digit LED for MIDI message info and Bluetooth connection status display
✪ DC 9-18V or 5V USB bus power supply
Specifications
Compatible Exp Pedal Pot Resistance
Max. 10kΩ
Power Requirement
9-18V DC center negative or 5V DC (USB)
Current Consumption
Max. 100mA
Working Range
≤5m
Dimensions
258.5mm (W) x 55.5mm (D) x 49mm (H)
Weight
440g
https://apps.apple.com/cn/app/ampero-control/id1526244402
The Ampero Control App is used to manage and edit Hotone Ampero Control MIDI controllers.
The Ampero Control App is used to manage and edit Hotone Ampero Control MIDI controllers. You can use it to edit pedal functions, set up MIDI messages, manage your personalized settings from the cloud, perform firmware upgrades, and more.
● Simple UI
We believe that no matter the novice or the old bird, they have had a lot of headaches about how to set up a MIDI controller. Therefore, we tailored this software for Ampero Control. With its straightforward operation and intuitive interface, you can personalize every detail of Ampero Control, with all the elements right in front of your eyes.
● MIDI message template
We have made MIDI message templates for some mainstream equipment in the software, you can directly call these templates to control your equipment, and you don't need to go around to find information. Of course, you can also store your own MIDI message templates and note their purpose.
● About Ampero Control
Ampero Control is a compact, lightweight and durable 4-pedal Bluetooth smart MIDI controller that supports full-featured programming and supports standard MIDI, USB MIDI and Bluetooth MIDI, making your MIDI control more flexible. You can assign up to 16 different MIDI messages to a pedal, and can be sent by setting different trigger actions for a wider range of usage scenarios. You can connect an expression pedal or pedal to the Ampero Control to expand the control of the Ampero Switch to further suit your needs. In addition, you can use the supporting mobile app to set up your Ampero Control in detail through Bluetooth, the operation is simple and direct, and you will no longer have to worry about MIDI programming.
● Product Features
• Small and reliable 4-step Bluetooth smart MIDI controller
• Supports standard MIDI, USB MIDI and Bluetooth MIDI messages in/through/out
• Optional MIDI message sending channel (standard MIDI/USB/Bluetooth)
• Sends up to 16 MIDI messages per pedal (32 with A/B group)
• 100 preset groups (each preset group contains MIDI message settings for 4 pedals, settings for two extended control interfaces, etc.)
• Different MIDI message triggering methods bring you flexible control methods
• Companion mobile app allows you to perform detailed settings on the device without a connection
• Two TRS expansion control connectors for connecting external pedals or expression pedals
• 3-digit digital tube screen for displaying MIDI messages and Bluetooth connection status
• 9-18V DC power supply or USB power supply
