tripleplay controlling volume of Jamstix
Started by ampedup, March 18, 2021, 07:22:25 AM
ampedup
I'm not using the tripleplay software in my daw, just using it as a midi controller. Whenever I turn on my tripleplay it turns the volume on my drum program down to almost off. Is there a setting in triple play that could be doing it?
ampedup
So I discovered that this happens when I pick up my guitar and bump the volume knob on the tripleplay controller. Is there a way to disable that volume?
It's common to assign Drums to MIDI Channel 10 only , and be sure all others stay clear of MIDI Channel 10 ( goes back to 1984 General MIDI Spec
What DAW are you using?
Full Tripleplay MIDI Spec is here:
https://www.vguitarforums.com/smf/index.php?topic=13653.0
ampedup
