GT-100: switching Boss ACS live pro
Started by TMB, September 17, 2020, 04:20:35 AM
TMB
Hello everybody,
I would be glad if someone of you could help me with the switching problem:
My setup
Hybrid guitar with 2 outputs
One signal in Boss ACS pro (piezo pickup)
A signal in tube amp (magnetic pickup)
As I often play both amps at the same time but here or there my ACS has to mute, it is quite a tap dance when switching to a distortion sound and at the same time to the mute of the ACS.
Also the dipswitching on the guitar is too complicated (i.e. it takes too long) => I want to mute the ACS at the same time as I press one of the switches on the GT100.
I do have an amp control on the GT100 but honestly I didn't use it because I didn't know about it. (as far as I've understood the manual the amp control works with mono cable and the ACS switch board is is connected via TRS) Unfortunately the ACS does not have MIDI. I have the GT100 only recently and will only be able to try it out with the two amps next week.
Is this an option (not tried yet)? Connecting the GT100 FS CTRL I/O with the ACS FS I/O ? => meaning there are on both devices options to extend the switches with BOSS FS?
Thanks a lot in advance for some helpful information.
Best regards,
Mark
