GR20 adjusts delay effects paramters?
Started by kpaul79, February 14, 2020, 10:43:13 AM
kpaul79
I was wondering if anyone knows if you can adjust the delay time on the effects (reverb/delay) on the GR20 or is it a set delay time ?
Quote from: kpaul79 on February 14, 2020, 10:43:13 AM
I think you can only add more or less or each. Turn knob counter clockwise for delay and clockwise for reverb.
From Roland supplemental document: Customizing GR-20 Patches
The DELAY/REVERB Knob
You can add either of two effects to a GR-20 patch to give it that final bit of polish: delay or reverb.
  • Delay—makes each note repeat a number of times.
  • Reverb—adds an acoustic space around the patch's notes to create the illusion that they've been played in a real-world room.
  • To add: delay to a patch—turn the DELAY/REVERB knob counter-clockwise. The further you turn it, the more delay you add.
  • To add: reverb to a patch—turn the DELAY/REVERB knob clockwise. The further you turn it, the more reverb you add.
kpaul79
thank you for responding, this has been so hard to find out this information. All searches bring back information about midi delay times, no effects parameters.
So the echo/delay time is a preset delay time?   Does anyone know if that can be edited ?
Quote from: kpaul79 on February 14, 2020, 11:08:19 AM
There is no indication in the documentation that these times can be adjusted.
Quote from: Brent Flash on February 14, 2020, 11:11:46 AM
^ Agreed!
FWIW - here is an updated GR-20 Owners Manual PDF   - which now has searchable text
https://www.vguitarforums.com/smf/index.php?action=dlattach;topic=15877.0;attach=20403
FWIW =the GR-20 is my least favorite due to the limited adjustment of the built in effects
But it can be firmware updated to support Bass instruments  with GK-3B
kpaul79
Thank you very much. That is a drag. From my research the GR-20 seems to have best sounds.
Quote from: kpaul79 on February 14, 2020, 11:41:56 AM
Its a matter of taste  - I much prefer the GR-33 Sounds
