GT-1000 - GT-1000 Mate Android app
Started by admin, December 16, 2019, 09:28:59 AM
GT1000 Mate - a fast patch switcher for the GT-1000 guitar effects processor
If you use a Boss(tm) GT-1000 guitar effects processor for live performances, or just use a number of different 'patches' (presets / tones), GT1000 Mate is a 'must have'.
The app reads all 250 patch names and their numbers (ie bank/patch) directly from the GT-1000 via a usb connection.
Ordered lists of the patches are created automatically. By tapping on a patch name in the list, the GT-1000 is switched to the specified patch. The switching is very fast - ie sub-second.
The lists of patches can be edited to change their order to match the required performance order (ie Set List). The editing can be done either using your favourite text editor, or (recommended) by using the KatanaSets app (sold separately) for full 'drag&drop' capability.
Once edited and saved, the updated patch lists are immediately available for use with the GT-1000.
FEATURES
- Sub-second patch switching at the tap of a finger
- Easily re-order access to your patches without changing the GT-1000
- Supports bluetooth devices such as foot switches for stepping between patches in performance order
- Allows direct control of the parameters for a small number of effects (PreAmp1&2, and Distortion DS1&2)
CONNECTION
Connection is via a USB cable and an OTG ('On The Go') adapter. The OTG adapter is required to enable the android device to talk to the GT-1000.
NOTE
Not all android devices will successfully connect to the GT-1000
https://www.eatonplan.com/forum
