SY-300 - Midi device to control each element of the SY-300
Started by udarnick, July 22, 2019, 05:15:14 PM
udarnick
I am hoping to have a midi device that I could hook up to the sy-300 where I could assign an individual knob to each oscillator, each lfo, and each effect.  This way then I could adjust any effect on the fly instead of going into the sy-300 control panel.
You can control 6 target SY-300 FX parameters
Create MIDI assignments in Boss TOne Studio for SY-300
MIDI controller Setup / Debug
ElliotG
You can use SYSEX to access all of the controls... There is plenty there without the sequencer and effects.  I created a program that is OSC/Filter/LFO...
udarnick
Quote from: admin on July 22, 2019, 05:20:15 PM
This is good.  I know about how midi works and I know about the tone studio.  I was hoping for a suggestion for a hardware midi device that I could assign a knob to each part so I could change the values on the fly.  The sy-300 has knobs on the outside of it, but I need to work my way through ui to get to what I need to change.  Is there any cheap midi device that could do this?
Any number of MIDI CONTROLLERS with an array of small knobs
But many use touchscreen with iPad running MIDI DESIGNER, and use a USB <>MIDI Cable
GuitarBuilder
Quote from: admin on July 23, 2019, 08:21:32 PM
I've used one of these with success; if you want lots of knobs, this is it:
https://www.behringer.com/Categories/Behringer/Computer-Audio/Desktop-Controllers/BCR2000/p/P0245#googtrans(en|en)
