Axon Ax 100 mkii.......can you trigger the internal sounds with midi in?
Started by gearhound22, July 22, 2019, 01:03:46 PM
gearhound22
Hi there,
I know the Roland GR-33 you can do it & the GR-55 you can't
I recently put my rack together and was surprised to see the FTP via midi host wouldn't trigger the Axon sounds via midi!
Maybe there is a setting I don't know about but same setup works no problems with a Roland GR-20 triggering the internal sounds.
I know the axon sounds aren't fantastic but some are ok and I was hoping to use them if I went wireless.
Shingles
Set the Axon to Local = Off.
I think it's in the Global or Utilities menu.
It's on the manual.
Nik
gearhound22
Quote from: Shingles on July 22, 2019, 11:58:34 PM
It's on the manual.
thank you!
maan108
gearhound22
Quote from: maan108 on July 23, 2019, 02:51:21 AM
..... have you check the midi channel used by FTP ???
Maan108
Funny enough I couldn't find the setting in the app!
But when I tried to trigger through another system it didn't work so 99% sure it was the Axon
I'm away for 3 weeks now though so cant try :(
